Hydraulic Motors
Hydraulic Motors
Home › Forums › Locomotives › Hydraulic Motors
  • #128616
    Carl Wilson 4
      @carlwilson4
      Hello,
      In the middle of a thought experiment that might lead to my building an hydraulic motor.
      Seem to remember a few years back seeing an article in either ME or EiM in which the author described construction of petrol/hydraulic loco. Think bent axis hydraulic motors had been made. Can anyone shed any light on this?
      Thanks,
      Carl.
      #1211
      Carl Wilson 4
        @carlwilson4
        #128628
        Ady1
          @ady1
          Put "petrol hydraulic" into the searchbox
          Linky
          There's a few returns with ME numbers
          5"g.petrol-hydraulic by Mr Faulkes
          petrol-hydraulic locomotive by C.Faulkes
          Mr Smith's petrol hydraulic locomotive
          G.T.Harris' 5"g. petrol/hydraulic loco
          etc
          #128629
          Ady1
            @ady1
            "Oilie", J.Harlow's petrol-hydraulic, issue 3526 page 1171
            and Oily is about right
            If you do take this route be prepared for a messy system which drips oily pollution everywhere
            The only hydraulic systems I've ever come across which didn't spew oil out all over the place are car jacks and fully enclosed automatic transmissions
            (I worked with hyd. pumps and cranes at sea. Bottom line is if it needs any pipes then it's going to get messy and smelly)
            Edited By Ady1 on 05/09/2013 06:40:07
            #128641
            Hi Speed Scrap
              @hispeedscrap
              Hi Carl,
              something like this may interest you, google, varspe.com, and
              download brochure.
              I made a few tiny ones similiar to these many years ago, they worked
              very well. (no connection to this company)
              Dave.
              #128651
              Carl Wilson 4
                @carlwilson4
                Hello,
                Thanks for all your contributions. I've also worked with hydraulics over many years both in aviation and marine settings.
                I'm looking at the feasibility of either trying to produce a gerotor type motor or a radial piston type. The gerotor would probably not be a true gerotor motor but rather an internal gear type motor. Similar to the more familiar external gear pump/motor but with an internal ring gear and smaller planet gear. A crescent shaped lobe seals the intake and outlet areas between the two gears. I'm trying to source some internal gear rings as I think it'll be easier to buy these than to make them. Anyone know of a source?
                The radial piston idea could be like a "Staffa" motor. A number of radially mounted fixed pistons would bear against an eccentric on the output shaft. As each piston extends the shaft rotates.
                Thanks again for all your help.
                Carl.
                #169128
                ChrisLH
                  @chrislh
                  Hello Carl,
                  Just noticed your enquiry and thought you may be thinking of Roy Amsbury's articles in Model Engineer some while back. He had a go at a 5 inch gauge Hymek locomotive and started of with a hydrostatic type transmission. This didn't work out in the end despite heroic efforts on Roy's part and he finished up with a mechanical transmission. It's all described in MEs for 17/06/88, 15/07/88, 19/08/88, 16/09/88, 21/10/88 and 18/11/88. Even if inapplicable or too late it's an interesting read.
                  Chris
                  #169134
                  Brian Wood
                    @brianwood45127
                    Hello Carl,
                    I'm rubbish at adding links, they never seem to work for me, but internal ring gears are available from HPC Gears at Chesterfield Derbyshire
                    http://www.hpc-gears.co.uk phone 01246 268080 email [email protected]
                    You may not like the price
                    Brian
                    Edited By Brian Wood on 09/11/2014 18:55:17
                    #169177
                    Gordon W
                      @gordonw
                      I don't really understand what you are trying to do, build a motor and pump from scratch? If not there are a lot of small motors out there. Some garden tractors had all hydraulic drive, flail cutters, golf carts etc. May be worth a look.
                      #169180
                      V8Eng
                        @v8eng
                        I know next to nothing about Hydraulics but for many years motor vehicles have been fitted with compact hydraulics for power steering etc.
                        Some (I'm told) have battery powered pumps, it might be an idea to check if there are any scrappies in your area to have a friendly chat with.
                        Edited By V8Eng on 10/11/2014 10:56:22
                        #169187
                        Carl Wilson 4
                          @carlwilson4
                          Thank you for your replies and help gents. As you can see this post is a year old now. It was originally a thought experiment. What I was trying to do was to distract myself and get some respite from the most traumatising and tragic event that has ever happened to me, and which has left me utterly bereft.
                          No need to worry, I have all the info I need if I ever decide to go anywhere with it.
                          Thanks again.
                          Carl.
                          #169228
                          Muzzer
                            @muzzer
                            There are quite a few cars nowadays with electrohydraulic power steering (EHPS), such as the BMW Mini and several Fords from memory. However, you won't find any hydrostatic motors in them, only the constant flow pump, control valve and rack (which contains the actuator piston). Even the smallest cars are going to have pretty large motors in them (about 1kW or so). I can't think of a smaller, commonplace application using hydraulics but they must surely exist.
                            Having worked with all of the major golf cart manufacturers, I can tell you that they all use electric drive (no hydraulics). Aerial work platforms, electric pallet trucks and small fork lifts might be a good place to look.
                            Murray
                            #169236
                            Mark P.
                              @markp
                              They have them on airliners known as HMG. hydraulic motor generator powered from the aircrafts main hydraulic system,used if the engine driven generators fail.
                              Mark P.
                              #169239
                              Les Jones 1
                                @lesjones1
                                Citroen cars with hydropneumatic suspension have an electriclly driven hydraulic pump that is used to raise the suspension to give different ride heights and suspension levelling.They normally only run for a short time so they may overheat if run continuously.
                                Les.
                                #169263
                                Carl Wilson 4
                                  @carlwilson4
                                  If I was going to do it I'd probably use something like a Danfoss OMM series motor. But I'm not so no worries.
                                  #169279
                                  Ian S C
                                    @iansc
                                    Some ride on mowers use Hydraulic motors for the main drive (either 2 or 4 wheel drive) and one for each cutter, the one I'm thinking of has 3, It is powered by a 3 cylinder Komasu diesel, a lovely little motor, quite quiet.
                                    Some of the machines we built for feeding out bails of hay were powered by a hydraulic motor from the tractor hydraulic system, the motor we used was about 4" dia x 5" long. This system replaced the wheel driven method used on most of our machines. Both systems have plenty of power, with 2 heavy bails on the deck they could weigh nearly 2 tons. Ian S C This is a hydraulic drive machine with an extra long deck to carry 3 bails of hay. Plenty of power in a motor that size for a small loco, and no leaks.test 036 (640x480).jpg
                                    #169443
                                    Carl Wilson 4
                                      @carlwilson4
                                      Gents,
                                      If I was going to do this then I would probably use something as shown in the photographs below. This is also a good example of the type of thing I have to deal with on a regular basis. You are looking at a subsea ROV operated milling machine with hydraulic motor drive to the leadscrews for the XYZ axis and the spindle. This machine is designed for a specific task in the process of removing old spool pieces from a subsea vertical riser. So I'll be doing some milling at 1300 metres. There'll be a plentiful supply of coolant.
                                      This shows an OML series Danfoss motor driving one of the leadscrews. Other pictures show the same motors driving other leadscrews on the unit.
                                      The gearbox and hydraulic drive to the cutter.
                                      #230915
                                      Chris Gibson 1
                                        @chrisgibson1
                                        I would like to build a small, radio controlled model (say 20th of full size) of a JCB with backhoe. I am trying to find details/drawings/information of cylinders, pistons and hydraulic pumps at suitable size. Can anybody suggest sources of books or drawings please?
                                        #230965
                                          Hello Chris,
                                          Glad you were able to find us!
                                          neil
