Combined Mill/Lathe
Combined Mill/Lathe
Home › Forums › Manual machine tools › Combined Mill/Lathe
  • #107303
    JC Uknz 1
      @jcuknz1
      With a very small workshop, to six foot benches on each side of a two foot or so aisle, I have been wondering about a combined mill/lathe. I have seen adverts for them in the past but a long web search came up fruitless.
      Does anybody know if they are still made and by whom? I am thinking of home priced versions of course though I guess a trade worksup will have room for two machines , lathe and mill.
      #12053
      JC Uknz 1
        @jcuknz1
        #107305
        Les Jones 1
          @lesjones1
          Hi JC Uknz 1,
          These combined machines are still made but I do not know who manufactures them. I have seen them sold by Machine Mart, Chester UK and Warco. There are probably other suppliers.
          From previous discussions on the subject most people recommend a separate mill an lathe.
          Les.
          #107307
          mark mc
            @markmc72333
            I know chester still sell one, but as above from all i have heard they a pita.
            #107309
            John Coates
              @johncoates48577
              I was considering one of these but found most reviews uncomplimentary as the combined nature limits both machines so it is the worst of both worlds. The mill is not rigid enough and only good for putting holes or slots in round workpieces held in the lathe chuck. And all that extra weight affects the lathe.
              So I went separate instead of buying one
              #107310
              JC Uknz 1
                @jcuknz1
                Chester UK have some mouth watering Centurions but I take you point about PITA . They look awkward to use without room in my case to swing the mill head out of the way.
                #107313
                  Concentrate your money into the lathe, perhaps enabling you to get a slightly bigger one. Using a vertical slide has always been a favourite and perfectly adequate for most modelling needs. It is just a matter of overcoming the psycological barrier of working 'sideways' and not being tempted by seemingly good ideas that aren't. Bit like people buying a soft top car in the UK.
                  #107315
                  Siddley
                    @siddley
                    They are awful machines, please don't buy one.
                    I actually got better work from my combined lathemill – never, ever again – by building a vertical slide for it ( using parts from an old shaper which had been broken down ) and going 'old school' as if the milling head didn't exist at all.
                    Whatever you do, do NOT buy a Clarke CL500
                    #107317
                    Springbok
                      @springbok
                      Do yourself a favour avoid the combos had one and the round pillar will give wiplash, This is the reason they do not sell well.
                      Use the difference in price to get a better lathe then afterward a small mill with horizontal jibs.
                      Good luck and a fun new year in the workshop.
                      Bob
                      #107323
                      Mike Clarke
                        @mikeclarke87958
                        If room really is a problem, I see Warco now do a milling attachment. I had something similar on my Emco and loved the combined machine…..no complaints.
                        Have a look, it's at the bottom of their milling machine page – looks a decent bit of kit (sold out at present).
                        Mike.
                        #107329
                        Ian S C
                          @iansc
                          Got a friend who has one, PITA would be a polite way of describing it, but his is worth putting up with, the previous owner thought the same and vertually gave it to him. I have used the lathe(don't think anyone has used the mill), and found it not too ridgid, and for the job I was doing the 100 mm chuck too small, my own lathe has 8" chucks.
                          Get a lathe, its just a mill laying down. Ian S C
                          #107474
                          JC Uknz 1
                            @jcuknz1
                            I have a lathe, as big as will fit in the area and a vertical slide so obviously the idea is to upgrade the VS with fittings for the work. I also have access to a mill and large lathe but my thoughts were on saving the travelling time to use them as they are on the other side of town. It too can be a PITB
                            Thank you all for your words of warning … appreciated truely.
                            #107522
                            Harold Hall 1
                              @haroldhall1
                              Whilst I have never owned, or know anyone who has owned, one, I have always thought the dual purpose machines to be very much less than ideal. The distance between the worktable and the head seems to be too great for one thing. Even the suppliers provide raising blocks to overcome this situation.
                              I agree with others that using a lathe with a vertical slide is a better option and see you already have these. Does the lathe have a tee slotted cross slide this. is esential?
                              If you would like to see examples of milling being undertaken on the lathe there are some projects on my website intended for the lathe only workshop, these will give you an idea of what is possible. The index for these is at (bottom right) **LINK**
                              As was mentioned by Bazyle working sideways can be a bit of a barrier but is not that difficult to accommodate. You could though, once you come to terms with using a vertical slide, consider making a milling head for the lathe such as seen here, a milling machine is not required for its manufacture. **LINK**
                              The following pages shows it being used for making the horizontal steam engine “Tina” and show that it is capable of some complex work. It is not quite as robust as using the lathes spindle and vertical slide but working that way can be reserved for any heavy duty tasks that surface. **LINK**
                              Harold Hall
                              #107819
                              Graham Green 3
                                @grahamgreen3
                                I hope no one is referring to this combo as a "load of garbage".
                                http://www.lathes.co.uk/emco/img10.gif
                                Brilliant combination and well thought out machine, if only the chinesey's had bothered to copy this model, then they might have had a winner.
                                regards Graham Green
                                #107821
                                Siddley
                                  @siddley
                                  Round column ? no thanks. Been there, done that, pain in the fundament.
                                  A lathe is a lathe and a mill is a mill, ne'er the twain shall meet unless you want to be very disappointed.
                                  But what the f— do I know, I've only been making my living from machine tools for the last 15 years
                                  #107822
                                  Thor 🇳🇴
                                    @thor
                                    The round column of the Emco mill has a key that keeps the head positioned. If yoy rotate the head, the column rotates with it.
                                    Regards Thor
                                    #107823
                                    JC Uknz 1
                                      @jcuknz1
                                      Thank you Thor … the Emco must have been the one I had seen and appealed to me as I don't have much room in my workshop as explained inm my first posting ….of course I could set up in the adjoining room but I had idea of turning that into a lounge at some stage.
                                      But thankyou very much all of you for your comments
                                      #107825
                                      Siddley
                                        @siddley
                                        Honestly, a lathe makes a very poor mill. But I promise not to argue the point from now on,,,
                                        #107844
                                        Mike Clarke
                                          @mikeclarke87958
                                          The original query was based around the problem of not having room for separate machines. There is no doubt separate machines are better to have.
                                          I don't like the automatic dismissal of combined machines though, my Emco lathe/mill combo was a joy to use and I wish I'd kept it (space and cash permitting!). I imagine the Warco attachment I linked to would offer similar satisfaction, but have never used it so don't know.
                                          Similarly – I love my 1960s Bridgeport style mill, but I know many who are happy with round column mills and have produced beautiful work on them.
                                          Mike.
                                          #107851
                                          Another JohnS
                                            @anotherjohns
                                            Kozo Hiraoka had, according to one of his books, a 8×8 workshop in the corner of the living room.
                                            His machine tool was an Emco (7" or 8&quot lathe, with the vertical head on the back of the lathe bed.
                                            Now, I understand that he did not actually build the last locomotive or two described, but the work that he did do on his locomotives that he did build is second to none.
                                            Another JohnS.
                                            #107855
                                            martin perman 1
                                              @martinperman1
                                              Gentlemen,
                                              I have a combination lathe and a round column Mill/Drill and they both serve me very well. Everything has limitations as do my machines but once you learn how to use them they do what I want.
                                              By the way my lathe is a Clarke CL500 and I make parts for restoring Petrol powered Stationary Engines, I've made some basic mods to it but it gives me no problems.
                                              Martin P
                                              #107860
                                              Bill Dawes
                                                @billdawes
                                                Don't' let people be too dismissive of machines such as the Clarke CL500M. I have one, bought about 3 yearsago, used pretty much straight out of the box and it has given me good service so far.
                                                As always you get what you pay for so it is not a toolroom machine and the mill head obviously has its limitations compared to a 'proper' milling machine, the main frustration I have had is when you alter the height of the head on its round column all your settings go to pot but the machine is quite a lumpy piece of iron and has been really useful as far as I am concerned.
                                                Having said all the above I am in relatively early stages of model engineering so guess I will need to aim higher at some stage in the future, but it has got me started at relatively small cost and I have not regretted buying it.
                                                Bill D.
                                                #110781
                                                Philip Burman
                                                  @philipburman66049
                                                  Golmatic looks like a credible combo alternative:
                                                  UK dealer and prices here. Sit down before you open the price list:
                                                  Phil
                                                  #110806
                                                  mechman48
                                                    @mechman48
                                                    I can agree with Bill Dawes; every machine has it's limitations,I had one for some years on a solid wooden bench in my garage & the lathe handled some hefty cutting..with care!. the milling aspect left me frustrated as you have to remove the chuck & fit some sort of raising block to limit the quill extension otherwise you get a noticeable vibration problem, (mind you I bought mine back in the 90's so was one of the earlier models & being on contract work most of my career it was rarely put to constant use).It was a pita to change speeds though changing belts and /or fitting the intermediate pulley to suit cutter dia.& material. otherwise a solid hunk of iron.
                                                    George
                                                    #110810
                                                    NJH
                                                      @njh
                                                      I guess a separate lathe and mill is the best option but if you don't have the space then that's a non starter. It just means that you will need to plan you work more carefully and make allowances for the deficiencies in ridgidity etc. – there again most of us with "hobby" machines need to do that anyway! It's only fairly recently that model engineers have the luxury of milling machines and I bet the likes of LBSC managed on just a lathe and would have loved a composite machine.
                                                      Learn the limitations of your equipment and work with them – let's face it even the most basic maching facilities beat the cold chisel, hammer and file!
                                                      Norman
                                                      Edited By NJH on 03/02/2013 12:04:30
