thread indicator
thread indicator
Home › Forums › Manual machine tools › thread indicator
  • #11833
    Nobby
      @nobby
      #76138
      Nobby
        @nobby
        Hi Paul
        Great photos . Has your lathe got a thread indicator ? Is it good for screw cutting ?
        Regards Nobby
        #76158
        Flywheel
          @flywheel
          Hi Nobby and Paul
          On the Grayson lathe that I used to own I fitted a Myford thread indicator. I engaged the indicator with the lead screw at the right hand end of the apron [as with the Myford] then spotted through the fixing hole in the indicator and then drilled and tapped the apron. By slackening or tightening the bolt the indicator can be engaged or disengaged as on the Myford,
          Hope this is of some help
          Regards Peter
          #76161
          colin hawes
            @colinhawes85982
            I have made one for my old 7 inch drummond lathe and used it on very many occasions over many years.
            #76456
            Nobby
              @nobby
              Hi Colin & Guys
              I have a drummond flat bed lathe & having problems with split threads . there is only one lever to engage leadscrew . Nobby
              #151674
              Paul Tummers
                @paultummers57940
                Any idea were to go to buy a Myford indacator for a Super 7 at reasonable costs?
                I badly need one in good shape.
                #151727
                Lambton
                  @lambton
                  Nobby,
                  I have a flat bed Drummond like yours. I have used it a lot for screw cutting with no problems. It is vital to keep the lead screw clutch ( as shown in your photo) engaged at all times and return the carriage to the start by reversing the lathe. Mine still has the treadle so this is a very quick and easy thing to do.
                  Hope this is of help.
                  Eric
                  #151734
                  Jon Gibbs
                    @jongibbs59756
                    Posted by Paul Tummers on 06/05/2014 23:22:02:
                    Have you seen this one?
                    Leaving everything engaged and putting the lathe into reverse is foolproof and the only way of cutting metric threads on the ML7 imperial version.
                    HTH
                    Jon
                    Edited By Jon Gibbs on 07/05/2014 16:44:25
                    #151740
                    Nobby
                      @nobby
                      Hi Jon
                      I have a S 7 Mk 1 and doing what Eric & Jon says works fine . so its worth a try . I do this using a mandrel
                      handle . or keep watching on Ebay
                      Nobby
                      Sprung loaded mandrel  handle
                      #151745
                      John Stevenson 1
                        @johnstevenson1
                        Very novel.
                        Looks like the steering box drop arm off a Leyland ?
                        #151758
                        DMR
                          @dmr
                          If Paul Tummers still wants a Myford TDI he can PM me for far less than flee-bay, and it's perfect
                          Dennis
                          #151765
                          Nobby
                            @nobby
                            Hi
                            Well spotted John . Did you notice it's sprung loaded for safety Similar to milling machines
                            Nobby
                            #151766
                            Paul Tummers
                              @paultummers57940
                              Posted by DMR on 07/05/2014 20:52:08:
                              Dennis
                              Thank you Dennis; it seems, I was too quick because today the man who has done the complete overhaul and conversion to metric mailed me, he had one for me, it was on the machine before he started working on it and belongs to my Myford, so it will be resprayed in Myford grey and then I can pick it up. I am a lucky guy, Myfordsolutions is only 10 miles from my house.
