(bicycle) thread identification?
Home Forums Beginners questions (bicycle) thread identification?
Viewing 25 posts - 1 through 25 (of 35 total)
  • #10790
    jon hill 3
      @jonhill3
      #538805
      jon hill 3
        @jonhill3
        I got roped into servicing a friends cycle and along the way of ordering new parts I thought it might be a handy to have a primer on thread identification.
        In this instance it was a set of replacement wheel nuts which if my measurements are correct are 9.5mm (3/8&quot x 26 tpi whitworth. I am aware that there are hundreds of thread types usually identifed by a 3 letter abreviation eg bsf, unf, bsp etc.
        Is there a handy reference ie: book, ytube video, website….
        #538809
        ega
          @ega
          Look up Sheldon Brown; it's all there.
          Or get Sutherland's manual if you have the money.
          #538814
          Russell Eberhardt
            @russelleberhardt48058
            Try **LINK**
            https://www.engineeringtoolbox.com/british-standard-cycle-thread-d_2041.html
            Russell
            Edited By Russell Eberhardt on 09/04/2021 11:07:54
            #538822
              Bicycles mostly use Cycle (CEI ) threads which are all 26 tpi, but are NOT Whitworth form.
              They are 60 degree. like Unified or Metric threads.
              British Standard Brass threads are also 26 tpi, but Whitworth form.
              #538863
              old mart
                @oldmart
                If the bike is old, the threads are likely to be BSC, but metric has been used for the last 40 years.
                #538874
                Bo’sun
                  @bosun58570
                  Another vote for Sheldon Brown.
                  #538881
                  Nigel Graham 2
                    @nigelgraham2
                    B.S. Cycle Threads:
                    60º included angle. Not Whitworth (55º  ) .
                    3/8" BSCy – 26TPI – Tapping Drill 8.5mm
                    Source: Newnes' Complete Engineers' Data Sheets.
                    Taps and dies are available from, e.g. Tracy Tools.
                    Edited By Nigel Graham 2 on 09/04/2021 17:38:08
                    #538912
                    Georgineer
                      @georgineer
                      Posted by Howard Lewis on 09/04/2021 11:47:25:
                      Howard, if I may add some information:
                      • CEI threads became British Standard Cycle threads when BS811:1950 was published. It is still available from the BSI if you have £186 to burn.
                      • Although many BSCy threads are 26 tpi, there are others including 24, 32, 40 and more. And left-hand of course.
                      • Although the thread flank angle is 60°, the actual root and crest profiles are different from Unified and Metric threads.
                      George B.
                      #538927
                      CHAS LIPSCOMBE
                        @chaslipscombe64795
                        Does it make any significant difference in practice (as opposed to theoretical considerations) if a thread is 55 or 60 degrees?
                        If I mate a 55 degree brass thread nut with a 60 degree CEI bolt, does it really matter?
                        I'm thinking here of motorcycle type applications, not extreme performance situations.
                        Chas
                        #538928
                        jon hill 3
                          @jonhill3
                          Thanks for all the help everyone! Note to Nigel my Whitworth thread gauge seemed to fit hence mistaken for such.
                          Again a book or website recommendation on threads going into pitch, tpi, history etc would be very helpful.
                          #538931
                          DMB
                            @dmb
                            CEI = Cycle Engineers Institute
                            Standardisation; humph! Umpteen different systems, all different in one way or another.
                            BA = 47.5° flank angle and all different pitches but each dia. related to each other by a constant.
                            Whitworth group, same flank angle 55 °, some constant pitch like ME 32,40,60TPI BSW, BSF, Pitch varies according to diameter and BSW 1/4"D for example doesn't have same Pitch as 1/4"BSF.
                            Brass is constant 26t Pitch.
                            Basically, nothing fits anywhere except within it's own system!
                            I believe that there is only one exception ; 1/4"dia Brass and BSF are interchangeable.
                            Trying to use a nut from one system to fit a bolt from another is likely to jam up tight.
                            #538932
                            jon hill 3
                              @jonhill3
                              Just out of interest the cycle im working one is only 6 yrs old. I am sure it is not the only new-ish cycle using imperial fittings.
                              #538935
                              Dr. MC Black
                                @dr-mcblack73214
                                I inherited a large number of 26 tpi taps and dies, including some marked LH, from a chum whose late father was a cycle enthusiast many years ago.
                                If anybody is interested in giving them a good home, please contact me OFF-LIST
                                MC
                                #538948
                                  Posted by CHAS LIPSCOMBE on 09/04/2021 22:58:16:
                                  Chas
                                  Generally speaking, in practice, it is common for 55 degree nuts to be used on 60 degree bolts etc and vice versa by home and professional mechanics. UNC and BSW fasteners have been intermingled for years in Australia with both being available and used, depending on which side of the pond stuff was imported from. Ordinary fasteners and fittings are made to loose enough specs they will screw together and work ok. I've seen plenty of Harleys with BSW nuts and bolts mated to the original UNC fasteners and Myford lathes somehow seem to end up with UNC fasteners coupled to BSW. It works.
                                  But precision threads such as the spindle nose threads and chuck threads on UK made Boxford clones of the US made South Bend lathes seem to be reluctant to fit UN chucks on BS spindles and vice versa, according to various owners in past posts on here.
                                  #538955
                                  DC31k
                                    @dc31k
                                    Posted by jon hill 3 on 09/04/2021 23:02:41:
                                    There is no one resource that will do that for you.
                                    A few steps on your path to screwing utopia:
                                    https://journeymans-workshop.uk/allthread.php
                                    https://www.gewinde-normen.de/en/index.html
                                    https://www.haguefasteners.co.uk/BoltingGuides/HagueFastenersGuideToScrewThreadSizes.pdf
                                    https://www.npl.co.uk/science-technology/dimensional/npl-notes-on-screw-gauges
                                    #538958
                                      That’s a potential problem with any identification … You can be easily misled when the pitch matches.
                                      A good thread gauge should match the thread profile very closely, and at 26tpi I would need to use optical magnification to be confident of a match.
                                        Tubal Cain's "Model Engineer's Handbook" is good reference, on many subjects,.
                                        Section 4 deals with many of the threads of that you are likely to come across
                                        There will be specials with non standard pitches for the thread size, as found on Mandrel noses, but the data on standard pitches, depths, forms, etc can be read across to the non standard sizes.
                                        You may even meet some real hybrids with Imperial pitches on a Metric diameter, or vice versa.
                                        Took a long while to work out that one Metric lathe had a 2 1/4 x 8 tpi Whit form Mandrel thread!
                                        #539038
                                        Nigel Graham 2
                                          @nigelgraham2
                                          I was wryly amused by those revelations of so-called "professional " mechanics using fastenings from one series on near-fits from others; but glad I don't use their garages.
                                          If I pay to have my vehicle serviced professionally, I damn' well do not to be later driving up the M6 at 70mph in a ton of steel held together with any rough old nuts that vaguely wobbled their ways along the studs!
                                          Mis-matched threads are not mating by flank area, but by very thin lines – what other short-cuts has the "professional " taken?.
                                          Bad practice does not become good by being common.
                                          Come on, we're not those can't-be-bothered-mechanics. We like to think of ourselves as model-engineers who do our best to get it right.
                                          A Cycle Thread is NOT Whitworth!
                                          #539047
                                            As in the oldest profession …
                                            Professional means “does it for money”
                                            angel MichaelG.
                                            #539048
                                            norm norton
                                              @normnorton75434
                                              It is all very well being pedantic and saying that a 55 deg nut cannot/must not be mated to a 60deg bolt, but you are talking about a couple of thou fitting difference and load being on a line contact rather than a full face. Does any one have data on how much less load a thread angle miss match can carry?
                                              But I agree, in principle, cut the right thread angle and do things properly. Does it matter for strength? we need to see some data.
                                              #539087
                                                From practical experience, I can say that BSW threads do not easily enter UNC tappings.
                                                Our Chief Engineer, (!!!! ) at the time would only countenance BSW or BSF, so a lot of Clayton Dewandre brake equipment had the UNC threads tapped out to BSW. Fortunately only retaining threads.
                                                Not what I would have done, but faced with an imkmovable object.
                                                #539088
                                                  Posted by Howard Lewis on 11/04/2021 08:19:09:
                                                  Was it an act of revenge when American Standard Inc acquired the company ?
                                                  Ref. https://www.gracesguide.co.uk/Clayton_Dewandre_Co
                                                  Edited By Michael Gilligan on 11/04/2021 08:44:11
                                                  #539090
                                                    Posted by Nigel Graham 2 on 10/04/2021 19:01:12:
                                                    Nobody said it was recommended best practice. Just that out there in the real world, it works.
                                                    Major fastener suppliers in Australia these days supply UNC fasteners as "BSW" when diameter and TPI match, so as to minimize their stock of genuine BSW. No law suits so far from them falling apart in use. On commercial grade mass produced threads, the exact angle simply is not that critical and manufacturing tolerances are so loose they they fit together and stay together without any problems at all. And on old bolts and studs that have been well used, the threads will be distorted anyway and bear only a passing resemblance to any original standard.
                                                    Putting a brand new 3/8" UNC nut on a 3/8" BSW bolt or stud on a motorbike or car is better than putting back a 75-year-old flogged out BSW nut that is one step away from stripping. And better than waiting three weeks for the genuine (premium priced) BSW nut to arrive from Ol' Blighty if the machine needs to be used.
                                                    It is however something I avoid because working on bikes with two sets of spanners required for the mixture of nuts and bolts drives me up the wall. But I have seen plenty of it done over the years, on just about every old bike ever and in industry where American and British machinery mix and matched fasteners over the years.  Never seen it be a problem other than the spanner size nuisance.
                                                    Edited By Hopper on 11/04/2021 09:24:34
                                                    #539094
                                                    Nigel Graham 2
                                                      @nigelgraham2
                                                      I wonder why the cycle trade stayed with 60º threads when (presumably) the Whitworth-form, 26tpi Brass thread was so common?
                                                      I have worked on Royal Navy equipment that would have odd mixtures of UNF and BA, advised of by labels, but leaving the technician to recognise which. It was easier on the larger fastenings because the UN-series had indicator rings stamped in them. That was a NATO effect. Other items though had some metric fastenings!
                                                      When I started my steam-wagon project, in what became a hopelessly over-ambitious 6" scale, I planned for UNF for 1/4" and above, and BA for anything smaller. (Plus ME series where applicable.) That was based on ready availability, including my comprehensive A/F -sized socket and spanner sets from servicing my cars; but also the neat appearance of the bolt heads.
                                                      Having started again in 4" – scale the thing so far as accumulated a bit of a mixture, which is not good practice, but I am slowly correcting that. The hexagon for 1/4" BSF, the predominant size for the chassis fastenings and closer to prototype, is slightly larger than the UNF equivalent, needing a BSF rather than UN (AF-sized) spanner, but aesthetically not noticeably so. .
