Hacksaw blade orientation – your opinion please
Home › Forums › Beginners questions › Hacksaw blade orientation – your opinion please
Viewing 25 posts - 1 through 25 (of 38 total)
  • #512980
    AJAX
      @ajax
      I decided to make a LEGO toy model power hacksaw with my kids. Don't worry, they won't be allowed to play with this until they are older! By including a couple of machine screws it was easy enough to mount a standard 12" hacksaw blade and to my surprise it works quite well. In fact, it has now got me wondering about making a small but usable powered hacksaw for those smaller jobs when a high TPI blade is required. Needless to say it won't be made from LEGO (or Meccano, for that matter).
      Bearing in mind my model has no blade relief (or rise) on the non-cutting stroke I was not too bothered about blade orientation. However, I stuck with what I was taught a long while ago. Looking online, I see similar working machines of basically the same design and wonder whether there is a preferred blade orientation and the reasoning (if any) why.
      I would be interested if you have some knowledge of experience to share.
      #10575
      AJAX
        @ajax
        #512993
          Teeth cutting on the ‘push’ [as per normal hand operated hacksaw] can buckle the blade if the frame is not very stiff.
          With teeth cutting on the ‘pull’ [as per fretsaw or piercing saw] the blade stays taut.
          Martin Connelly
            @martinconnelly55370
            At school the rule for the bent wire junior hacksaw frames used to be cut on the pull stroke as it was safer if the blade caught. The wire frame could spring and release the blade if the blade was the other way and then you drove your hand into the workpiece. Proper frames with tensioning such as the Eclipse ones had the blades in the conventional direction. It is easier when manually sawing to push the blade forward and down to cut than pulling the saw and pushing it down.
            I would think about the link that moves the frame. If it was really flimsy then a pull cut would be better as the load on a push cut could end up bending it. You should try to make it strong enough to work in either direction but the tensile force being greater than the compressive force still makes sense. If the bow it at a high position for a large piece of stock the link has to work against gravity as well when pushing the frame up.
            Martin C
            #512997
            Ady1
              @ady1
              cutting on the pull is best
              #512998
              Steviegtr
                @steviegtr
                What a load of rubbish. You always cut on the push. Teeth pointing forward.
                The only time i have known for a pull action is when working with the Sikh carpenters who kneel down & cut upwards & towards them. Teeth pointing backwards. Strange to watch.
                Steve.
                #512999
                gary
                  @gary44937
                  my rapidor cuts on the push stroke
                  #513000
                  Kiwi Bloke
                    @kiwibloke62605
                    Posted by Steviegtr on 12/12/2020 00:55:25:
                    Steve.
                    Well, of course, that's a 'load of rubbish', unless suitably – and massively – qualified. As MG had previously noted, fretsaws, piercing saws cut on the pull stroke, as do jewellers' saws, many (most?) types of Japanese woodworking saws, chainsaws, bandsaws, etc., etc.
                    AJAX, I suggest you set the blade in the direction it works best – that's all that matters. Of course, with a suitably rigid frame, a hacksaw pulls the blade…
                    #513001
                    Ady1
                      @ady1
                      For a human the push stroke is usually best but for a mindless mechanical machine pulling is best and causes the least problems
                      #513002
                      Kiwi Bloke
                        @kiwibloke62605
                        Posted by Ady1 on 12/12/2020 03:41:01:
                        Tell the Japanese – and a lot of non-Japanese who understand their advantages – to push their pull-saws then…
                        Broaches are usually(?) pushed. It may seem strange, because pushing invites buckling, but the reason's clear, after a bit of thought.
                        #513012
                          Steve.
                          No, Steve … it’s not a load of rubbish, and I do not always cut on the push
                          I suggest you remove the blinkers, and look at the world around you.
                          AJAX
                            @ajax
                            Posted by Martin Connelly on 12/12/2020 00:15:44:
                            Martin C
                            I haven't had to use one of those wire framed hacksaws for many years, but the point you make is valid. Thanks.
                            #513015
                            Brian Wood
                              @brianwood45127
                              Posted by Kiwi Bloke on 12/12/2020 04:25:39:
                              And a good number of broaches work as pull devices, there have to be equally good reasons for that approach as well
                              Brian
                              #513023
                              Mike Poole
                                @mikepoole82104
                                Martin makes a good point about the wire junior hacksaw and they work fine in pull mode, a normal manual hacksaw would be more tiring to use in pull mode as only arm power would be used,in push mode you can get your weight behind it. I know the saw should do the work but you do need to apply enough weight to make the teeth cut rather than skid and of course you do need to apply the effort required to cut. I think the expression is for those who think you can force the saw to cut faster by applying excessive weight to it. With the Lego saw the frame has limited rigidity and strength so pull may be best in this application. For a reasonably fit person sawing should be an activity that can be maintained without tiring or breaking too much of a sweat, a good technique should result in accurate sawing and minimal filing. Sawing a three inch bar by hand is a daunting prospect but can be done with a bit of effort and patience. The fact that so many of us use machine saws would tend to indicate that sawing is not a popular activity or maybe time is better used in other more interesting activity.
                                #513044
                                  As most of us on the forum are likely close to (or beyond) the ‘normal’ retirement age, manual sawing is best reserved as a gentle exercise – not like 50 years ago (for me).
                                  Thinner blades are better for sawing but that needs to be tempered with rigidity. Most conventional hand timber saws cut a wider kerf than our metal cutting examples but have much wider blades to keep them sufficiently rigid to enable a push-cut.
                                  This has all been mentioned, sort of, above – where pull saws are considered. With a band saw the tension will always be there when cutting, whatever the motor position. The differences likely arise with the rigidity of the band saw frame. Lightweight has its disadvantages, particularly when built down to a cost rather than up to a quality.
                                  The mass of the motor on a ‘pull’ machine will have less effect as cutting proceeds, compared to the motor at the top end of the frame. Note the springs added as a modification by the chappie in the video on the other thread. In fact, it will be positioned at the optimum balance point on the well-designed machines
                                  #513050
                                  Peter G. Shaw
                                    @peterg-shaw75338
                                    I must admit that I have never thought about reversing the blade in a junior hacksaw, but then I haven't had many problems in the conventional direction. But, food for thought.
                                    I also have a Stanley Mini-Hack Saw, part no. 20-807 which I use in awkward situations. On checking, I find that I do indeed have the teeth the "wrong" way round, and furthermore, the illustration by Stanley clearly shows the blade inserted in a pull direction.
                                    Interesting, and thanks to Ajax for raising this subject. Yet again I've learned something.
                                    Peter G. Shaw
                                    #513051
                                    roy entwistle
                                      @royentwistle24699
                                      I much prefer the old style hacksaw where the handle is in line with the blade like a file.
                                      Roy
                                      #513052
                                      Baz
                                        @baz89810
                                        I was always told to insert a hacksaw blade with teeth facing forward, same for junior hacksaw so you push to cut, but fretsaw etc the other way round so you pull to cut. Kennedy style hacksaw machines I believe are best set up to cut on the pull stroke, but it is entirely up to you, whatever you feel more comfortable with.
                                        #513053
                                        Nicholas Farr
                                          @nicholasfarr14254
                                          Hi, as far as power saws, that is reciprocating or band, it is really down to the manufacturers design, as to which way the blade is moved and it doesn't matter if it's towards the fixed jaw or the moving jaw, I've used both types in both directions and towards both jaws. (but not all those ways at the same time or on the same machine) At one time in my old job, we had a band saw that "pushed" the blade towards the moving jaw, one time when the blade needed changing, a guy who thought he knew best, put the blade on the other way round thinking that it should be pulled, guess what, the blade jammed up on the very first cut and ripped a couple of teeth out of the blade. I told him to have a look at the fitting instructions, which were hanging on the back of the machine, that clearly stated that the blade should be cutting forwards toward the moving vice and must not be fitted the other way. Like Gary's Rapidor my one cuts by "pushing" towards the fixed jaw and the oil dashpot lifts the blade away from the cut on the backward stroke and the reciprocating action pushes it down on the cut in the forward stroke. However, when in a ridged frame on power saws, the blade is in effect pulling the teeth which ever way round it is, it's just the design of the machine that makes the difference.
                                          As far as hacksaws are concerned, pushing on the blade is normal, but at times when there are space restraints, put the blade the other way round so you pull, works much better, horses for courses and all that.
                                          Regards Nick.
                                          Edited By Nicholas Farr on 12/12/2020 11:42:27
                                          #513061
                                          Martin Kyte
                                            @martinkyte99762
                                            I don't think you can 'push' a blade in a frame. You can push and pull the frame but the blade will always be pulled by the end of the frame leading the cut. I think Nicholas said that above. Weather the blade cuts on the forward or reverse stroke is another matter. The saw geometry will determine if more force is exerted downwards on the forward or reverse stroke. (or indeed if it's symetrical). Basically is the crank offset above or below.
                                            Bandsaws allways cut towards the driven wheel for obvious reasons.
                                            regards Martin
                                            #513067
                                            Nicholas Farr
                                              @nicholasfarr14254
                                              Hi Martin, band saws don't always cut towards the drive wheel. In the one I mention above, the cut was away from the drive wheel, hence the guy who put it on the wrong way round thought he was fitting it correctly.
                                              Regards Nick.
                                              Edited By Nicholas Farr on 12/12/2020 12:32:08
                                              #513073
                                              Robert Atkinson 2
                                                @robertatkinson2
                                                Well the blade was being pulled from the other side,
                                                It depends where the tensioner is or / and how stiff the sructure is.
                                                if bandsaw drive and tensioner are before the workpiece (in direction of blade movement) its still a pull, there is just a fixed pulley (or more) between the drive and th pull.
                                                Put another way if the axis of the drive pully is aligined with the cutting plane is that push or pull?
                                                Robert G8RPI.
                                                Edited By Robert Atkinson 2 on 12/12/2020 12:46:47
                                                #513086
                                                Bill Phinn
                                                  @billphinn90025
                                                  Posted by Kiwi Bloke on 12/12/2020 02:59:31:
                                                  Just for the record [you probably know this, Kiwi Bloke] chainsaws cut on both the push and the pull stroke, depending on which side of the bar you are cutting with. When plunge cutting with the nose of the bar, the saw teeth cut on the push and pull strokes simultaneously.
                                                  #513088
                                                  bricky
                                                    @bricky
                                                    I have used japanese pull saws for years but they were soon used only for bench work as site work was to demanding on the upper arm muscle when cutting tmber.I could see the same being true on a large hacksaw but it would not pose a problem on a junior one.
                                                    Frank
                                                    #513102
                                                    peak4
                                                      @peak4
                                                      It's interesting to not Ian's observation on the previous page about his jeweller's vice having the fixed jaw at the front.
                                                      This would fit well with piercing and fretsaws normally being used as pull saws.
                                                      Also, and I've never worked with precious metals, it would allow the metal shavings to land in the same place, regardless of the moving jaw's position. This would be quite important when sawing gold.
                                                      I've often seen jewellers workbenches with a leather sheet suspended below the vice to catch the metal dust for re-use.
                                                      In my own workshop, I'm in the slightly odd position of having three power hacksaws, all of which are designed to cut on the push stroke; I understand that most cut on the pull, with the teeth read facing.
                                                      The little Kennedy is quite clear in the instructions that it should be set to cut on the forward stroke.
                                                      My larger Denbigh very obviously works that way around as the dashpot works on an eccentric cam off the main spindle to provide pressure relief on the return stroke.
                                                      Finally the mid sized Manchester Rapidor Minor (9" blade) isn't immediately obvious. On closer inspection, the angle of the blade isn't parallel to the motion of the frame in which it sits. It is lower at the rear, so when it cuts on the forward stroke, the dashpot provides pressure relief on the return stroke.
                                                      I understand the same is true of the larger Rapidors as well, It you look at the drawings on Tony's site, one of them even has a badge on the top of the frame showing the teeth set forwards.
                                                      Oddly in all cases they cut towards the moving jaw of the vice.
                                                      I've seen several larger power hacksaws which cut on the pull stroke, where the dashpot provides both relief and also pumps the frame back up under no sawing lead.
                                                      Handsaw wise, I normally use a 12" hacksaw to cut on the push stroke, with junior hacksaw, fret, coping and jewellers/piercing saws cutting on the pull stroke.
                                                      Most of my wood saws are traditional British/US, but I do have a genuine Japanese double edge saw, cuts on the pull, with cross cut on one side and rip on the other. ( I probably bought this in the early '80s)
                                                      I also favour the cheap Aldi/Lidl saws which also cut on the pull stroke; pull saws allow for a much thinner blade and thus a narrower kerf.
                                                      Bill
                                                      Edited By peak4 on 12/12/2020 14:41:22
