“Your Sketch Is Not Closed,” says Alibre Atom, “So tough!”HERE?ERE?
Home Forums CAD – Technical drawing & design “Your Sketch Is Not Closed,” says Alibre Atom, “So tough!”HERE?ERE?
  • #809762
    David Jupp
      @davidjupp51506
      Nigel,
      Atom3D does have the Shell tool mentioned by Jason & Martin.  It can hollow out a solid, and remove selected faces at the same time.  Shell is almost certainly faster than either of the modelling approaches you have just outlined.  Shell only requires one sketch for a simple case – either the internal or external profile.  Having only one sketch, without any offsets, makes subsequent edits easier.
      https://help.alibre.com/articles/#!alibre-help-v28/features-standard-features-shelling-creating-a-shell
      The method chosen ultimately depends upon
      • Which tools you are comfortable using
      • The final purpose of the model
      Sometimes you want to model the full details, reflecting how it is constructed – other times you might just want something that has the correct shape and need not include fine detail.
      blowlamp
        @blowlamp
        I don’t have Alibre, but you should be able to get your shape from just a rectangle, a fillet and a shell in pretty much the same way as I did in this video.
        Shell Example
        Martin.
        #809873
        Nigel Graham 2
          @nigelgraham2
          Oh yes!
          Thankyou Jason – I was confused by earlier discussions on what each Alibre version has.
          I’ve just had a quick play to see how it works, with a just a box with two rounded corners.
          #809876
          blowlamp
            @blowlamp
            You don’t even need to round the corners in the sketch. You can use a rectangle and then fillet the edges of the solid, then use shell.
            Martin.
