My brother was Transport Manager for Tarmac at Ettingshall in Wolverhampton. The fleet was Fordson ET6 and 7s The ET6s had been converted from 32 hp petrol V8, to Perkins P6, so that they were like the ET7s. The P6 was a good engine but the Areoflow combustion system had a large surface to volume ration, so KiGas was obligatory for a cold start. The MD had a centrally heated garage for his car. So in winter, after he had left, one of the tippers was left there overnight. Once started it tow started one of the others, and then there two available to tow start the rest of the fleet.
Some fenland framers built concrete ramps and parked the Fordson E27N tractor at the top, ready for a bump start next morning.
The Ford 4D and 6D engines were D I s and were superb cold starters.
In the CAV cold chamber the fitters had rubber faced table tennis bats, so that if a Thermostart misbehaved, or the engine tried to run backwards (Not unknown ) the bat went over the air intake and stifled the fire.
If a vacuum governed engine started running backwards, you had to have the courage to open the throttle wide. Leaving it closed merely pushed the control rod over to full fuel. Trying to stall by engaging the clutch in top gear with brakes full on would sometimes split the gearbox casing! And all the oil from the oil bath air filter was blown out and over everything!
The Perkins Prima in the Montego and Maestro, and as the Industrilaa500 Series, would start unaided at -5C
Scrape the frost off the screen, crank and drive away!
Now the ECU takes care of everything, heater plugs and all!
