Hi Danny,
As Graham's photograph shows, the fundamental issue is that the column bracket is fixed by three screws that are almost in a straight line. This is compounded byy teh mating surfaces being poorly finished,
I greatly improved my X2 by scraping the joint surfaces to get amuch bigger contact patch (I also corrected a slight lean in the column this way – it was along slow job that turned my fingers, if not the air, blue).
I also fitted a triangular stiffening plate of 4mm steel between the column swivel bolt and two M12 screws and spacers at the rear corners of the base casting.
The improvement in surface finish and rigidity was noticeable and further imprved by fitting roller bearings and belt drive.
I wrote these modifications up in (I think) MEW issue 199.
I'd stress that the newer versions of the X2 with a non-tilt column don't suffer this fault. As mentioned earlier, a conversion kit for the old X2 is available from Arc Euro.
