Hi Brian,
And thank you Neil – yes Mr Radford's mod with a slight twist…
As your S7 is narrow guide, then measure the gaps (left and right) with feeler gauges between the back of the saddle and the vertical faces of the rear shear. On mine the gaps were <> 19 thou. They should be equal, most likely not – the fixed narrow guide which bears on the rear of the front shear is worn and the gib is unable to be set correctly causing the saddle to rock. Or the gib has been set incorrectly causing uneven wear on the fixed guide.
The bed on my S7 shows very little or even wear but I still converted it by removing the saddle to clean out any debris at the rear the saddle and inserting a 1/2 inch wide shim just a tad thicker than the measured gaps at the rear – no machining required. This effectively converts the saddle to wide-guide principle (after <> 1973) making use of the unworn rear shear. The shim (brass) must be just thick enough to move the saddle back to the unworn position (on mine the shim is 20 thou) creating a small gap between the rear of the front shear and the worn fixed guide on the saddle.
Readjust the saddle gib-strip, taking care to have equal pressure on all screws – my S7 now faces as good as flat, over 5" and I can move the saddle to the tailstock end without any binding, showing that the bed is not unduly worn. It took less than a couple of hours to carry out and has restored the accuracy of the S7. If you now measure the very small gaps which have been created at the rear of the front shear they will most likely NOT be equal, proving that this is the wear point.
The shim has stayed in place with stiction, but it does need the later "bridge" shaped wiper on the front of the saddle to replace the older "rifle" type. There is a small chance that swarf will enter the small gap that has been created, but I fitted a swarf tray anyway to minimise swarf on the bed in front of the saddle.
This mod. is completely reversible – just pull out the shim and readjust the saddle – no harm done.
I've obtained a spare saddle to carry out a more drastic machining operation to fit a 1mm thick Turcite strip in place of the shim but that has gone onto the to-do pile for now.
As a point of interest, does anyone know what the factory clearance was at the rear of the saddle? Having this measurement would help me restore the saddle to it's designed position and reduce any misalignment of the lead-screw and half nuts.
Phil
Edited By CotswoldsPhil on 16/09/2015 15:32:19
