Where have the picture numbers gone?
Home › Forums › Model Engineer & Workshop › Where have the picture numbers gone?
  • #38379
    Tim Stevens
      @timstevens64731
      Latest issue Dec 2016, pp9-15, 47-51
      #269237
      Tim Stevens
        @timstevens64731
        It is sometimes difficult to keep track of which picture shows what, when articles are split over several months. But when the illustrations are not numbered at all, it really becomes a nonsense. Is there a reason for this?
        Tim Stevens
        #269284
        mgnbuk
          @mgnbuk
          I had noticed this also, trying to follow the gearcutting article. I have not found this to be the easiest article to follow with the illustrations numbered – without numbering I gave up trying last night.
          Proof reading oversight perhaps ?
          Nigel B
          #269297
          Gordon W
            @gordonw
            I am pleased to read this, I had thought that I was loosing the plot. This morning I had an idea and checked for missing pages, all seem to be there. Maybe lost at printers ?
            #269298
              @mike89748
              Every picture should have not just a number, but a caption beneath it explaining what it is, otherwise readers are bound to get confused.
              #269306
              Tim Stevens
                @timstevens64731
                Too much star gazing means not enough proof reading, I reckon.
                And yule greetings to y'all.
                Cheers, Tim
                #269322
                Circlip
                  @circlip
                  And every forum posting should have a number too.
                  Regards Ian.
                  #269344
                    Maybe the authors did not supply numbers and Neil played safe by leaving as is rather than risk putting the wrong number against a photo, can't proof read what is not there.
                    Circlip, every post does have a unique number, you just need to know where to look, this is post number 2099233 of thread number 122704. We have covered this before
                    Edited By JasonB on 01/12/2016 13:19:14
                    #269355
                      No, I just found the numbers here in an envelope blush
                      Sorry for the mistake – we have had a few errors over the last few issues as I get used to a different workflow with a new designer.
                      The gearcutter pictures are 27, 28 and 29 if anyone wants to write them in; not sure it was that hard to figure out which is which without the numbers.
                      Arduino starts with photo 9 and they follow in sequence.
                      In general terms, I try to number all photos and caption them where it makes sense to, but if an article is illustrated by several angles of the same item I won't put captions like 'yet another picture of it but from the left hand side this time'.
                      Many authors don't include captions, and if possible I get back to them and ask for a list, but if I don't get this in time I may have to make them up myself. Naturally author's own captions are better as they can highlight key points.
                      Sometimes I get articles without photo references; it can be a struggle to ensure they go in the right places.
                      Sometimes I get captions and references but the numbers don't match the photos – this is a bit like solving a jigsaw…
                      A few authors don't supply either captions or photo references – at this point I start losing hair…
                      Sometimes I get a very large number of photos without captions or references and a note 'I've sent you plenty of photos so you can choose the best ones to illustrate the article' – at this point I lose the will to live
                      Ian P
                        @ianp
                        Posted by JasonB on 01/12/2016 13:17:13:
                        I my local doctors waiting room there is a photocopy of an article about the practice that appeared in the local newspaper. The article was about how good the practice was, and one of the topics related to the difficulty patients experienced when trying to make appointments. The spokesperson for the practice put the problems down to people 'not asking the questions in the right way'!
                        Post number knowledge must fall into the same category, it might have been discussed previously on the forum but how does that help me see the numbers if I want to use them?
                        I suppose I could use this websites 'search' function but I would not know what question to ask.
                        Ian P
                        But why does it have to be a secret anyway
                        Edited By Ian Phillips on 01/12/2016 15:21:44
                        #269359
                        Peter Krogh
                          @peterkrogh76576
                          I'd sure like to see the post number right up there in the green stripe, plain and obvious!!
                          Pete
                          #269362
                          Old Crock
                            @oldcrock
                            Am I missing something? I can see the advantage of numbering photographs when cross referred to in an article.
                            Will those who advocate cluttering up the posts with a forum number please explain the benefit to the majority of readers. Saying you want it is one thing but you have failed to make a case!
                            #269364
                              Having a number does make it easy if you want to refer someone back to a comment you made earlier in a thread or when linking to another thread you can link directly to a specific post. This is avalable on a lot of forums.
                              #269365
                                Posted by Ian Phillips on 01/12/2016 15:20:12:
                                Ian P
                                No secret Ian, as I said it was discussed earlier and you even took part in the discussion. I found it with 20seconds of using the site search function, "post number" seemed the obvious term to search for. Did not post a link earlier as needed to get back out to work but here it is again.
                                Edited By JasonB on 01/12/2016 16:31:31
                                #269491
                                Old Crock
                                  @oldcrock
                                  Fair point Jason and point taken but as it will probably help only a minority of users on this site can it be kept discrete? I suppose hiding it is as it is now is discrete!
                                  I searched on "Post Number" and it told me there were no exact matches.
                                  Satchll
                                  #269492
                                  Circlip
                                    @circlip
                                    ega 23/01/2016 12:17:02
                                    419 forum posts
                                    41 photos
                                    Numbering of posts:
                                    What I (and, I thought Circlip) had in mind was the facility of posts being numbered sequentially *within* their thread ie 1, 2, 3 etc.
                                    Each post is already date and time-stamped and it would to my lay mind seem a small additional step to number them. This would make navigating and contributing much easier and cut down data-hogging repetition.
                                    Thought ega made it abundantly clear Jason but since it needs repeating.
                                    Regards Ian.
                                    Edited By Circlip on 02/12/2016 10:05:54
                                    #269493
                                    Circlip
                                      @circlip
                                      Oh dear, and I thought the deadly underlap had been solved. Just shows how a better class of idiot can screw the system.
                                      Regards Ian.
                                      #269550
                                      Ian P
                                        @ianp
                                        Circlip
                                        Not sure what you mean about 'data hogging repetition', the fact that posts are date and time stamped (using 18 ascii characters) does not help anyone link to, refer to, or find particular post.
                                        I cannot work out who wrote the text 'Thought ega made it abundantly clear Jason but since it needs repeating.' as the posting (in this thread at timed 12:17:02) has two green header bars!
                                        In any event, whatever the useful information is, I don't think its actually been repeated so I'm still in the dark about where to find the post numbers.
                                        I had three different attempts to use the forum search but none produced any results
                                        Regards Ian.
                                        PS I have just realised that there is no point in me knowing the post numbers if nobody actually uses them.
                                        #269571
                                          Circlip (who wrote that line) is making the very valid pont that on this site the numbering system is not really much use to anyone and very difficult to use if you wanted too.
                                          Other sites have a # 1, #2, #3, etc somewhere along the top which would put it in our green header and it is easy to refer to or link to a particular post number.
                                          As has been said previously it is unlikely to change any time soon.
                                          J
                                          #269596
                                          Tim Stevens
                                            @timstevens64731
                                            I have opened this site in two programs, and in neither can I see any numbering of the Forum comments. There is a date and time in the green stripe, nothing else.
                                            But I expect it is one of those odd features which the office can see but no-one else …
                                            Tim Stevens
                                            #269609
                                              Nerd Alert!
                                              Line 287 of the source code starts:
                                              <tr class="RowStyleHeading"><td width="100">
                                              <a href="/members/public_profile.asp?c=133523">Tim Stevensa>td><td>
                                              <a name="2099877">02/12/2016 18:33:17a>
                                              Once a post number (emboldened above) is identified you can link to it. But not it seems from the same thread! Not much use I think.
                                              Edited By SillyOldDuffer on 02/12/2016 19:42:01
                                              Edited By SillyOldDuffer on 02/12/2016 19:43:21
                                              Edited By SillyOldDuffer on 02/12/2016 19:45:02
                                              #269611
                                                Easiest way to se the number is to hold your mouse over the "send to a friend" tab at the bottom of a post, it will end in something like p=2099233 which is the post number as Michael Gilligan pointed out the link I posted yesterday but obviously not much point in being able to link back to posts and threads if people don't read them..
                                                It is possible to link back to a post in teh same thread, this is the one with the link in it from yesterday. Should put that thread at the top of the page. No Moderators magic tricks used to get that link.
                                                Sachll, if you use the Google search on the home page you will have more luck as the search at the top of each thread only looks for thread title.
                                                Edited By JasonB on 02/12/2016 20:24:00
                                                #269618
                                                  I learn something new every day…
                                                  #269626
                                                    Posted by Neil Wyatt on 02/12/2016 20:40:55:
                                                    I forget something new every day…
                                                    #269634
                                                    Nick Wheeler
                                                      @nickwheeler
                                                      Often, I discover that what I learnt yesterday isn't true.
