Super Simplex Build
Super Simplex Build
Home › Forums › Work In Progress and completed items › Super Simplex Build
Viewing 26 post (of 26 total)
  • #875145
    Peter Hoerlein
      @peterhoerlein37724
      Here is the completed motion brackets
      IMG_2520
      Martin Evan’s design includes reamed holes in the frame to align the brackets.
      IMG_2571
      Next was the cross heads.  They were a little tricky to make.  The blanks were milled to size and the boss was roughly cut to shape.
      IMG_2522
      The cross head was mounted in the four jaw and the boss was centred using the two dead centre method and the then machined down.  A special tool was ground to machine the boss down as much as possible.
      IMG_2523
      The boss was turned down a little more to leave the bead around the front edge.
      IMG_2525
      The front boss was then finished off on the bench with needle files and sandpaper.
      IMG_2521
      The cross heads were then finished off on the mill. I used a couple of angle blocks to get to machine the inside of the cross heads the set was a bit sketchy but worked ok.
      IMG_2536IMG_2537IMG_2538
