Couple of nice new lathes
Home › Forums › The Tea Room › Couple of nice new lathes
Viewing 1 post (of 1 total)
  • #875257
      I was watching this yesterday and thought these took the ELS to the next level
      First should start at 13.34, a nice solid manual lathe with the ELS and speed control panel to the left, not quite sure where the lead (ball?) screw is but possibly down the middle.
      The second  at 17.40 has what is probably best described as handwheel twiddling by wire where the handwheels are similar to a MPG and send their signal to the motors not directly to a screw. A turn of a knob effectively increases the feedscrew pitch so you have slow, med and fast movement for the same amount of rotation.
      Better still is the same sort of thing to the functions on a DRO for things like Arc and Radius but it is done by “feeding” with the third handwheel which will see both carriage and cross slide move as required. Or you can just go full CNC.
      It’s enough to make a Myford user think twice😉😉😉
