wheel size accuracy?
Home › Forums › Beginners questions › wheel size accuracy?
  • #166904
    nigel jones 5
      @nigeljones5
      im just completing the wheels for my 71/4 Invicta, thing is ive turned one a tad undersize. What sort of size difference will not cause me issues? thanks
      #7340
      nigel jones 5
        @nigeljones5
        #166911
        Jeff Dayman
          @jeffdayman43397
          Gnat's eyelash 'tad' or loose like a sausage in a rubber boot 'tad'?
          A few thou won't matter IF your coupling rod holes are a little sloppy by the same sort of tad.
          JD
          #166917
            No coupling rods on an 0-2-2!
            I would have thought the biggest problem is it will go round in circles if you try and run it without any rails
            I'm sure I have read about full size engines occasionally having significant tyre diameter differences without ill-effects.
            nigel jones 5
              @nigeljones5
              its 18 thou undersize….don't know what I was thinking!!
              #166974
              Ian S C
                @iansc
                You could take the other one down to match maybe?
                Ian S C
                #166977
                Spanna
                  @spanna
                  Once the wheels are n the axle, its best to give a final truing skim. Do both on the one setting
