Insulating the roof will prevent heat loss and keep moisture away from cold roof sheets, preventing condensation..
A well insulated shop will suffer less rapid temperature swings, reducing the risk of condensation.
In winter, it will warm up more quickly, or cool down more slowly.
In summer there will be less solar gain to the interior, so is less likely to give heat stroke!
My shop has 50 mm wooden frames with glass fibre between the 19 mm wooden outer cladding and the inner 12 mm ply on all four walls. The door end is 100 mm framed, to take the weight of the fire door.
(6 lever lock and hinge bolts for security )
The roof is rubber covered 12 mm ply on 50 mm frames with 12 mm ply ceiling, again glassfibre insulated..
High on the back wall is rainproof vent to a very rarely used 6" intake fan . Almost at floor level are two small fixed, permanently open vents.
The floor is 3/4 ply on 8 x 2 bearers, which have walls very close by on three sides, low at far end and front, 6' fence.against back wall. On top of the floor, on the areas on which I walk, there are hard plastic mats about 25 mm thick.so that I don't get cold feet .
Front wall is 8' high, rear wall 7'6". Outside dimensions are 10' 6" x 6' 9" with no windows.
My friend who built it said, "You'll spend most of your time with the door open" I do!
In winter, being small, a 2 Kw fan heater runs for about 10 – 15 minutes before the thermostat operates. The fan then runs for about 5 minutes every 30 minutes or so when the door is shut.
Location East Anglia, UK, so temperate. The ambient temperature range, in the course of a year is probably -5 to +30 at most.
At the risk of now being proved wrong, rust is almost unknown.
