What is a good quality lathe paint
Home Forums General Questions What is a good quality lathe paint
Viewing 25 posts - 1 through 25 (of 25 total)
  • #401227
    Grant Allen 1
      @grantallen1
      I'm looking for a good make brand of paint for repainting my myford after being sand blasted. Would I also require a good etch primer any advice gratefully received.
      Grant Allen 1
        @grantallen1
        To spray up the lathe after being sand blasted
        #401237
        David George 1
          @davidgeorge1
          Hi Grant The original finish on the Myford was done by filling the castings and smoothing with filler and repeated to look smooth. The filler is quite thick to look corect and if you sandblast the castings you will have to repeat this to get same Finnish. I would look at sanding and filling any damage and spraying on top of original filler.
          David
          #401239
          Andrew Tinsley
            @andrewtinsley63637
            You would not believe how thick the filler can be! I followed David's advice and then used Paragon paint. Take a look at their web site it is full of good advice.
            #401240
            Pete Rimmer
              @peterimmer30576
              I had my lathe cabinet sand blasted, but no other part of the lathe. Hopefully you understand what bits absolutely MUST be protected Grant.
              Apart from that any good enamel paint will do the job. I use Arcforce enamel off ebay along with their grey zinc phosphate primer.
              #401244
              Grant Allen 1
                @grantallen1
                I thought that it would of had filler, I assume its car body filler ? I know that any machine face is precious is there anything else I should watch out for. I will certainly be looking at those paint suppliers you have all mentioned.
                #401247
                Stueeee
                  @stueeee
                  +1 for Arc force paint. I use Arc Force paint on my machines too. They will do any BS or RAL colour. I've recently painted this newish to me lathe as part of the restoration process. This is BS Dark Admiralty Grey.
                  It is basically a spray paint but does brush on OK for smaller stuff. Available here -usual disclaimer.
                  Plasma
                    @plasma
                    To make the castings look good lots of P38 body filler and elbow grease is required.
                    It's more like dealing with car bodywork than engineering machinery.
                    I would not grit blast anything, preferring thinners and flap wheel grinding discs to strip away the old finish. Blasting in my opinion is just not worth the effort and risk of something getting damaged either in transit or in cleaning.
                    I use Teamac plant and machinery enamel paint on my machines but there's no reason the other enamels mentioned here won't compare just as well.
                    #401260
                    Grant Allen 1
                      @grantallen1
                      From your advice on here I wont be blasting it I knew it would take it back to metal but looking at the amount of filling to get that smooth finish I'm just going to flap wheel it. Looking at the enamels it brings back memories of the tractor we had and the new Hudson autocycle I restored.
                      #401275
                      Joseph Noci 1
                        @josephnoci1
                        Interesting that you folk recommend enamel paint – in our hemisphere, enamel paint is a generic name for the type of paint used in household applications – gloss and semi-gloss for doors, door frames, exterior facia boards, etc. This tends to be a turpentine solvent based paint and does certainly not stand up to machine lubrication oils and water soluble coolant, etc. Strictly utilitarian , white goods, and never on machines! So, your enamel must be something else..
                        My machines, generally 'green' – use a 2 part acid etch primer, and a two part epoxy base paint. Tough as nails, withstands all oils, turpentines, thinners, etc, and very scratch resistant.
                        Joe
                        #401278
                        Grant Allen 1
                          @grantallen1
                          It had crossed my mind, acid etch primer brilliant stuff had good results in the past.
                          #401281
                          Mike Crossfield
                            @mikecrossfield92481
                            Tractol enamel is superb for machinery. Tough as old boots. High pigment content and slow drying, so you can get a good finish using brush application. Spaying even better. Available in a huge range of colours. Ferguson grey is a good match for Myford grey. Smith and Allen is a very helpful UK stockist.
                            #401298
                            Roger Clark
                              @rogerclark
                              +1 for Tractol, used it to restore my Denham Junior and Record vice.
                              #401304
                              Vic
                                @vic
                                I've used ready mixed filler on metal before.
                                then a couple of coats of Primer Filler then top coat.
                                #401314
                                Pete.
                                  @pete-2
                                  I'd use a 2k Acrylic gloss top coat automotive paint on top of 2k filler primer, this gives a very tough gloss top coat that looks like powder coating.
                                  #401315
                                  Pete.
                                    @pete-2
                                    Joseph Noci, what Lathe is that in your photo?
                                    #401328
                                    Chris Evans 6
                                      @chrisevans6
                                      Stueee, I dream of owning a DSG
                                      Back to original post. Plus 1 for Tractol paint.
                                      #401331
                                      Russ B
                                        @russb
                                        I used a company on ebay called Paints4trade, very knowledgeable, they can make anything you want. You can also get Toluene and other useful solvents for cleaning really stubborn grease/grime stains.
                                        The enamel paint I bought was specifically for plant and machinery and was Xylene based. Just go easy on the Xylene and Toluene as they are a bit toxic, affects the nervous systems etc. Well ventilated area needed!
                                        Tractol is a Xylene based enamel paint too.
                                        Edited By Russ B on 20/03/2019 08:13:15
                                        #401342
                                        David Standing 1
                                          @davidstanding1
                                          Posted by Peter F on 19/03/2019 23:49:36:
                                          Maximat V10-P
                                          #401359
                                            Posted by Joseph Noci 1 on 19/03/2019 19:20:41:
                                            'Enamel' is another of those words that's bent it's meaning over time and space. Originally 'enamel' was a baked on coating, heatproof, very hard and durable, applied to domestic ovens and cast-iron baths etc. Usually but not necessarily white. Expensive, can be done on a small scale, but really needs a largish kiln. Still found on posh cookware.
                                            Later 'enamel' came to include 'hard wearing paints that look like real enamel', or, less desirably, 'any soft paint that looks a bit like real enamel'. Usually in the UK the hard wearing definition is what's meant, but what's available ranges between high-performance 2-part paints, and cheaper, less tough, mixtures. It is also possible to buy 'enamel' paints that aren't hard-wearing at all, making Grant's question a good one.
                                            David Standing 1
                                              @davidstanding1
                                              Posted by SillyOldDuffer on 20/03/2019 11:17:20:
                                              Dave, I would have to put my pedant hat on, and challenge you on that.
                                              The first type you refer to has traditionally been referred to as stove enamelling. It still very much exists, and sits side by side with other (non baked) enamels.
                                              Whilst I agree that the second is a catch all encompassing many types of 'enamel', it is still true that there is a separation, as there always has been, between baked stove enamel, and air drying (all the others).
                                              You haven't even mentioned powder coating, which probably sits uncomfortably between the other two categories wink
                                              #401362
                                              ega
                                                @ega
                                                Whilst it is true that bath paints exist, I think the norm is vitreous enamel ie baked on glass.
                                                #401552
                                                AdrianR
                                                  @adrianr18614
                                                  I used to live on a canal boat and had a few old tins of green paint spare when I repainted my boat blue, all 60' of it.
                                                  My dad used it to repaint his Drummond lathe, it came up perfect. I now have the lathe, and the paint is still good. No problems with oil effecting the paint.
                                                  I can totally recommend International Toplac. Also when I did the repaint, I used an additive to improve the flow and reduce brush marks. I think it was Owatrol Oil.
                                                  #401591
                                                  David K
                                                    @davidk77137
                                                    lathe (8).jpgI did my Myford about two years ago, as already said keep the old filler coat on . Once you sand off the paint the filler is easy to sand and you can get a nice finish .
                                                    I used HMG Paints C71 enamel **LINK**
                                                    Use a good primer , I used HMG again , still looks good today.
                                                    #402212
                                                    Grant Allen 1
                                                      @grantallen1
                                                      The M type I am restoring has been 3 colours green, red, cream. Looking at the machine colours I see there can only be 2 colours myford green or grey.
                                                      Now my question is should I stick to the original colour or go different with an age related colour, my new Hudson was 1957 and was maroon, a really lovely colour
                                                      If I could work out how to upload a photo I could show you all and make a decision green, grey or maroon
