What Did You Do Today (2016)
Home Forums The Tea Room What Did You Do Today (2016)
Viewing 25 posts - 1,176 through 1,200 (of 2,143 total)
  • #249846
      Posted by SillyOldDuffer on 08/08/2016 09:45:03:
      Not only is it bent, it's unwound as well! I'm not sure where I bought it as it was loose in my spares box. I think it's probably a cheap DIY store drill intended for woodwork but even so…
      I would guess you bought that one in Wensleydale, Dave
      They are pobably O.K. for drilling cheese.
        Posted by Michael Gilligan on 08/08/2016 10:41:02:
        Given time I might come up with a Zummerzet joke about the superiority of our Hard Cheddar to those soft girly northern cheeses. As it is I've failed miserably.
        The disaster has got worse. Close inspection reveals that it's a 3.2mm drill, and I really do need it to be smaller. I've successfully made another beautiful reject for my scrapbox. The 3 is clearly indented on the shank but the 2 is very faint. Lessons learned: avoid cheap drills and check before cutting!
        Cheers,
        Anonymous
          Posted by SillyOldDuffer on 08/08/2016 11:01:06:
          Avoid any sort of cheap cutters; they're cheap for a reason. smile
          #249862
          Ian S C
            @iansc
            I'v got a tin of reject drills, there is a 1/8" one there that looks almost identical to Daves. About 40 years ago dad bought a set of drills through an offer in his Wood Work magazine, they were supposed to be guaranteed best English manufacture, after that he allways bought NZ, or Australian made.
            Ian S C
            #249937
            Windy
              @windy30762
              Had the steamer at Kingsbury Water Park the mods I'd done new section of generator tube and altering fuel and water pump flow certainly seemed to increase power it was like a greyhound setting off.
              Looked like it could be 130mph then prop broke the vibration certainly loosened a few things main one pressure release valve. Fitted another prop but was not happy with it and generator popped maybe the reduction in steam at high speed caused overheating and destroyed the tube material? Strip down tomorrow will know if tubing degenerated then if not the prop was not correct. Pushing the limits in experimental speed machines whether model or full scale certainly can cause headaches but when success is achieved its worth it.
              Did some stripping (model boat) this morning before corrosion sets in.
              Cylinder head had certainly got hotter than usual but engine seems good.
              The fresh bit of generator tube had burst at the hot end so indications are the replacement prop loaded the engine too much and burst the generator.
              Not enough load on engine and genny cools.
              Too much then stalls or pop goes the genny.
              The old steam cars had various temperature and pressure control systems e.g quartz rods to reduce temperature when too hot but they were after reliability not absolute speed.
              Full size steam vehicles have the room for these safeguards but the model weight is a strict rule and fractions of an ounce can push you over that limit.
              The balance between success and disaster is a fine line and any alteration to hull, engine, generator, prop or skeg angles can open another fresh set of headaches.
              Everything that is altered is recorded so always a record of success or failure.
              disaster after Kingsbury 7  August 2016
              #249968
              Michael Green 2
                @michaelgreen2
                Had a chuckle when I looked at the latest MEW and saw it had an article about using CNC for complex shapes.
                Sent these off to a friend today – all manual…
                Nickel plated is original; bronze versions are copies.
                Michael
                #249971
                john carruthers
                  @johncarruthers46255
                  Now the clock is mostly finished I've had some time to play with a Stuart S50 casting set.
                  Had it running on air but it's still a bit tight.
                  (please excuse the temporary feed pipes).
                  Edited By john carruthers on 09/08/2016 08:15:05
                  #250011
                  Sam Longley 1
                    @samlongley1
                    Sailed the boat from bradwell to ostend yesterday. Single handed. Had some winds up to 30knts at start but soon settled to 15-24 kts so good sailng weather for 90 miles
                    Autopilot packed up as usual so hard work hand steering and kn….d at end Big swell made getting sails down hard in the dark but now safely berthed
                    Here for the Paulusfesteen then the family come over until end august. When they go home 2 friends coming over on eurostar & we will have a couple of weeks cruising the Dutch canals
                    Lets hope the weather is better than it was for the 7 weeks i have just had cruising the channel isles & n brittainy
                    #250402
                    Nicholas Farr
                      @nicholasfarr14254
                      Hi, today I fettled a tilting table that I bought quite a while ago but never have used. I have a little job for it, but there were one or two issues with it, First of all the top side of the feet that are used to bolt it down on the milling machine were not very parallel with the underside, which meant that the bolts were only touching under the head at one point, this I didn't like at all, because I thought that it would put undue stress on the T-slots and I couldn't feel that solid feeling of tightness one would expect. The worst one of the two was about 1mm taper from one side to the other and about 0.5mm from the inside to the outside. So after a bit of mind boggling, I decided to mount it in a vice on my milling machine with one of the feet uppermost and using a long series end mill, carefully mill the taper off.
                      I took several light cuts, as I did not want it to suddenly snag on any hard spots that may have been there and rip it out of the vice or even break it. As it happens it machined very sweetly. This next photo shows how badly it was tapered at the worst end from the right hand side to the left hand side.
                      The next issue were the shaped washers that nip the underside of the curve in the base section. Needles to say, they did not match the curve at all well.
                      The best I could do was to hold them in a hand vice and file them as best that I could for a decent fit to the curve.
                      Yes, the one unfiled really shows what an atrocious shape they were.
                      The final issue was that the table would not tilt either way to its maximum position, this was due to the bolts hitting the bottom inside corner of the slots, so using a carbide de-burrer in my battery drill to remove enough metal to allow the table to move just past the maximum mark both ways on all four corners and I just smoothed them off a bit with a small stone in my Dremel.
                      It now swings both ways nice and smooth and just past the last mark and bolts down to the table with a positive feel.
                      Regards Nick.
                      Edited By Nicholas Farr on 11/08/2016 23:55:55
                      #250405
                        Well done, Nick star
                        Sow's ear now bears a passing resemblance to a Silk Purse !!
                        thaiguzzi
                          @thaiguzzi
                          Made another 5 Dickson type toolholders for my Bison QCTP. Get 5 out of one slab with the 8" stroke on the Boxford shaper. T slot and dovetail style design are a doddle on a shaper, and i still only own slot drills, end mills, and a couple of slitting saws for my mill's armoury. No expensive dovetail or t slot cutters in sight.
                          To speed things up this time, i actually cheated and cut the slot for shank tooling on the mill. That was tedious the last time on the shaper.
                          Now up to 19 holders. I think i've got enough, one sits permanently empty for the odd special…
                          #250606
                          Old Elan
                            @oldelan
                            Posted by thaiguzzi on 13/08/2016 06:36:16:
                            Wouldn't like to go into production, would you?
                            I could do with a few more but not at Dixon or Bison price!
                            #250609
                            Aeronut
                              @aeronut
                              Blimey, I'm at lot slower, only on number 4 for my ARCEURO QCTP and that's taken me a month.
                              Regards Lee
                              #250626
                              Bazyle
                                @bazyle
                                Just had a go on a Kubota mini digger on a friends farm. Wheeee! I want one.
                                #250632
                                  I found the floor in my workshop!
                                  Space making drew to a temporary halt as my portable drill went flat trying to put up a hook to hang a telescope from the ceiling.
                                    What's harder than finding a needle in a haystack?
                                    Finding a LR44 cell dropped into a bin liner full of aluminium swarf. It's impossible.
                                    #250645
                                    Clive Hartland
                                      @clivehartland94829
                                      And no doubt shorted out by now! Reminds me of a batch of batteries that came pushed into that anti static black foam, all dead as doornails at £12.00 a throw.
                                      #250646
                                      Peter Krogh
                                        @peterkrogh76576
                                        Posted by Clive Hartland on 13/08/2016 19:37:28:
                                        Really make one wonder, doesn't it?
                                        Pete
                                        #250647
                                          ROFL
                                          #250651
                                          Roger Provins 2
                                            @rogerprovins2
                                            Posted by SillyOldDuffer on 13/08/2016 19:09:51:
                                            Magnet on a stick? wink
                                            #250660
                                            Muzzer
                                              @muzzer
                                              Get down the pound shop and buy another half dozen…
                                              #250667
                                              Muzzer
                                                @muzzer
                                                Wasn't today – actually Thursday but no internet access at the time.
                                                I did my RYA Dayboat Certificate in Belfast Loch (Mirror dinghy) when I was in my mid teens and haven't been back in a yacht since. Fixed that to some extent this week by spending a few hours in a proper wooden-hulled, gaff-rigged Icelandic schooner. We were technically on a whale-watching trip (we actually spotted a hump-backed whale at close quarters) but the highlight came on the 90 minute return trip, when the crew hoisted all the sails apart from one of the jibs(?). We'd actually slept in it in the harbour the previous night, just the 4 of us, so it was interesting to see it given full pasty with a decent wind.
                                                Hildur schooner
                                                A couple more pictures in my album.
                                                The company that operates these boats has a "hybrid" drive on one of them. This allows electric motoring (stealth mode!) and recharging the batteries when under sail, presumably using the propeller to regenerate.
                                                Murray
                                                #250670
                                                Peter Krogh
                                                  @peterkrogh76576
                                                  Aye, that's a proper ship she is!!
                                                  Pete
                                                  #250671
                                                  thaiguzzi
                                                    @thaiguzzi
                                                    Posted by Old Elan on 13/08/2016 10:47:55:
                                                    I dare not even look at a new Dickson price! Last time i looked Bison holders were £30 odd quid upwards (plus VAT) for my T.1 size.
                                                    I've finally got round to adding a new album with some of the procedures, machining, and finished articles, these were from the first batch nearly a couple of years ago.
                                                    #250676
                                                    Speedy Builder5
                                                      @speedybuilder5
                                                      Thiaguzzi, I hope the box marked 'Fingers' next to the screwdrivers is empty. Looks like a great job, but its not fair showing us that you saw the holders off in pairs!
                                                      BobH
                                                      Edited By Speedy Builder5 on 14/08/2016 07:35:29
                                                      Edited By Speedy Builder5 on 14/08/2016 07:37:21
