Yesterday made good progress with the FeedRodMotor mounting plate for the BH600G.
Ready to start threading the spacer rods, only to find the Tailstock locking lever just spinning merrily, with not a hint of 'lock'.
'Oh bother!' said I. Remove a shelf and 'junk' (her indoor's not my description) that was preventing the Tailstock from being removed, and the offending lump of CI was on the bench for inspection.
IF I had been bothered to spend a minute checking the Manual, I would have seen that the nut holding the Clamping Block had probably unwound, and it had.
Tailstock back in position and then hands squeezed in to turn the nut till the locking lever did as designed.
Brain in gear for once, and 'That nut is going to unwind again at some inopportune moment'.
Tailstock off again. An M12 Clambing Bolt, a stud, holds the Clamping Plate in position, with only a couple of threads showing past the nut so no hope of a lock nut, but I don't have a beast that size in any case.
Out came a punch and one of the bolt threads deformed such that I couldn't unscrew the nut by hand.
I could have used a suitable grade of Loctite, but the bolt and nut where oily and I just wasn't @rsed to take them apart to clean, being that I'd spent nearly all day in the Garage/Workshop, and this after recovering from that flipping head cold.
Back onto the Carriage went the Tailstock and it locked up as before so I could finish threading those rods.
Job done for the day.
Geoff – Ready for Workshop duty
