Weight and transportability of a Myford lathe
Home › Forums › Workshop Tools and Tooling › Weight and transportability of a Myford lathe
Viewing 25 posts - 1 through 25 (of 52 total)
  • #202128
    Roger Custance
      @rogercustance46401
      I'm sorry that this is not a very exciting question, and arguably it is in the wrong place, but I don't know where else to put it. I am buying a Myford Super 7 lathe and would be very grateful to learn of its approximate weight and how best to transport it. Is it beyond the strength of two men to lift it into a reasonably sized estate car? Are there specialist firms for such heavy and awkward items? Do any members have experience of moving such a lathe, perhaps with cautionary tales to tell? The distance involved is nearly 200 miles.
      #17810
      Roger Custance
        @rogercustance46401
        #202132
        Bob Brown 1
          @bobbrown1
          FYI
          Approximate weights with electric motor:
          Standard ML7: 185 lbs. (84 kg). Long-bed ML7: 215 lbs (98 kg)
          ML7R: 240 lbs (109 kg) Long-bed ML7R: 270 lbs (122 kg)
          Super 7: 245 lbs. (111 kg.). Long bed Super 7: 275 lbs (125 kg)
          A screwcutting gearbox adds about 15 lbs
          #202137
          Roderick Jenkins
            @roderickjenkins93242
            Remove the motor, slide off the tailstock and wind the cross-slide off. Two chaps can then manage a S7. It is somewhat unbalanced toward the headstock. I found that with a bit of rope round my neck helping to support the headstock end and my wife on the other end we were able to manouvre the lathe into the car and out at the other end at the last house move – mind you, we were younger then! (16 years ago)
            HTH
            Rod
            #202140
            Nick_G
              @nick_g
              Posted by Bob Brown 1 on 27/08/2015 10:15:48:
              FYI
              So basically a door stop or a paper weight then. laughwinkwinkwink
              Nick cheeky
              #202141
              Ajohnw
                @ajohnw51620
                If you need to move it some distance a small sack truck helps – lathe head down. I've used one I bought from Wicks or B&Q several times. It doesn't matter if it's shorter than the lathe within reason.
                If you are going to transport it in an estate car ect a plank helps a lot. Rest the plank on the back of the car, place lathe on it and slide the lot in. Helps getting them out too.
                Hillclimber
                  @hillclimber
                  Having moved one recently in my estate car, all the advice is sound. But it is easier with three old guys – two at headstock-end with a strap, and one 'steering' the light end.
                  Also, I found a large piece of thin ply on the floor of the car to be useful (perhaps better than a narrower plank). You will then be able to lift the heavy end in first and simply slide the tail in. Do use some good tie-downs/ rope to keep it in place.
                  Dont forget a box and some dustsheets or something to wrap the taistock etc in.
                  cheers, Colin
                  #202146
                  Bob Rodgerson
                    @bobrodgerson97362
                    I remember well buying my Myford ML-7 from Osbournes in Newcastle in 1980 (Long since Defunct). I was home on leave from Brunei and decided that I was only going to come home to work in the North Sea within the year and I would buy the lathe now and store it in my house that we had also bought whilst we were on leave.
                    The lathe came on a kind of pallet and had a stout cardboard protective box over the top of it. At the time I had hired a Toyota Corolla hatchback and the lathe wouldn't fit in the back of the car without the box being removed. With this removed two of the lads from Osbourne's helped me get it into the back of the car.When I got home I made up a platform so that I could slide the lathe onto it and leave it there. I backed the car up to the platform in the garage workshop and proceeded to try and push the lathe out of the back of the car by leaning over the back of the passenger seat. Whilst doing this the seat back seemed to be getting lower and lower which aided me in getting better force to push the lathe out.
                    What I didn't realise was that due to all the strains and general pushing and shoving using the back of the seat as a lever point had collapsed the square tubing farm of the seat back. I straightened the seat back as best I could but every time I accelerated the back would start collapsing.
                    I often wonder what happened to that car after I returned it to the hire company. The next driver would have a hell of a shock when they accelerated.
                    #202147
                    Anonymous
                      From the weights quoted above it should be no problem moving it in an estate car; it weighs less than a couple of people. I am happy moving up to a ton by myself, after that I use specialist movers. If nothing else over a ton tends to exceed the trailer and/or towing limits of an ordinary car. I moved this cylindrical grinder by myself, with an engine crane, over a distance of about 120 miles:
                      Grinder
                      The key is ensuring that everything is blocked and tied down in all axes of freedom, especially if you need to stop in a hurry. No point in having the lathe in the front seat with you.
                      #202149
                      David Clark 13
                        @davidclark13
                        I would not remove the motor unless the electrics are on the stand as reconnecting the electrics can be a pain. If you do have to disconnect the electrics, use a digital camera to photograph the connections or otherwise mark them if they do not have colour coding. If they are on the stand, bolt the motor to the stand with the foot bolts. Two people can manage to lift the lathe easily. I used to take the heavy end and the wife took the tail stock end. I have managed to lift one on my own when I was a lot younger. If the motor remains on, the lathe will be back heavy and try to roll over. Two planks of wood about 18" long bolted to the feet will stabilise it.
                        #202151
                        JA
                          @ja
                          I moved a small milling machine of similar weight without difficulty. Three of us managed to get it into a small van at the dealers. At my workshop it was slid out of the van (it was on a sort of pallet) onto a small table with castors. Fortunately this was at the right height. The table with the machine on it was carefully jacked up to height and the machine slid off onto its cabinet. Luckily I did not have to negotiate any steps.
                          A couple of pictures.
                          Millingn machine on tableMilling machine on cabinet
                          JA
                          #202155
                          Gordon W
                            @gordonw
                            If you can get one, an offcut from an old aluminium ladder is very useful for sliding machines about. Second the sack barrow.I would not ask my wife, doesn't know left from right and tends to wander off at wrong moments, your experience may differ.
                            #202158
                            Roger Custance
                              @rogercustance46401
                              So many kind contributors here and so much useful advice that I shouldn't really be able to go wrong with the move, d.v.
                              Forgive me if I don't return thanks to everyone individually as they deserve – there are just so many.
                              Perhaps the main thing is that I now feel encouraged to go ahead on my own, well, with my son to assist (or do most of the lifting, with any luck, since I am 69), though he doesn't know about it yet.
                              I'll let you know how it goes, though the move is still a little way off.
                              Roger
                              #202161
                              Swarf, Mostly!
                                @swarfmostly
                                Hi there, Roger,
                                I second what has been written about the balance difficulties – I had an un-tutored assistant to help me lift the lathe (at that stage with the motor still in-place) off its stand. It took us by surprise and we managed to bend one of the bolts in the raising blocks. Fortunately, Myfords (at Beeston then) had spares.
                                Last time I moved my ML7 I had to get it from the car (an estate ) to the bottom of the garden. I used a builder's wheelbarrow. The barrow has an inflatable tyre which made the bumpy ride an awful lot easier than it would have been with a solid tyre.
                                The lathe was lifted off the barrow on to a pile of railway sleepers (part of the garden 'landscaping' ) just opposite the shed door. We then rigged two scaffold boards, one on top of the other, as a bridge through the shed door and slid the lathe up on to the bench. That got it to the same level as the previously positioned stand. From there it was a manageable two-man lift on to the raising block bolts. It helps to position a few pieces of wood in the swarf tray to support the weight of the motor until the mounting bolts are secured.
                                An 'island' position for the lathe stand is much to be envied. In a workshop as small as mine, the lathe has its back close to the wall and attending to the motor wiring or motor mounting bolts is a pain in the derriere!
                                Best regards,
                                Swarf, Mostly!
                                Edited By Swarf, Mostly! on 27/08/2015 12:30:07
                                Edited By Swarf, Mostly! on 27/08/2015 12:31:16
                                #202169
                                Roderick Jenkins
                                  There used to be a regular advert in ME back in the 80s(?) from one of the dealers with a (big) chap cradling a series 7 lathe in his arms. A better man than me.
                                  Rod
                                  #202170
                                  Bob Brown 1
                                    @bobbrown1
                                    Just get Terry Hollands to assist, he'll pick it up on his own and put it where you want it laugh
                                    Bob
                                    #202171
                                    Ajohnw
                                      @ajohnw51620
                                      Posted by Hillclimber on 27/08/2015 11:03:17:
                                      cheers, Colin
                                      It easy to get back and arm injuries getting heavy items in and out of a car etc because the roof is lower than a suitable van and people have to reach out and bend hence the plank. It also helps prevent any damage to the car. In fact I have managed to get several lathes out all on my own via a plank and then move it all in one piece with a sack truck. I mentioned an avoidable problem I had with one getting it onto a bench in another thread. I really should have removed the head stock but lacked a spanner bent to suit a Boxford's head stock fixings. I should have bent one there and then.
                                      Myfords heads are probably best left on because of alignment problems but I believe that the screws that come in from the side are used to tweak that. I have heard claims that Myford use some sort of magic material under the head but having dismantled and removed 2 head stocks I've not seen any signs of it.
                                      True there is a need to watch a lathe doesn't fall off a plank. Some are wider than others. Some lathes are also more lopsided than others. Steadying something is a lot easier than actually lifting it though.
                                        Unicorn grease.
                                        Bob Youldon
                                          @bobyouldon45599
                                          Hello Roger,
                                          Having recently had the task of removing a Myford S7 from a roof space! down three flights of stairs to a waiting car I can safely say a couple of strong chaps is the essential component; the lathe was stripped of all items capable of being removed easily on site. Get somebody to weld up a "Tee" shaped bar from about 12mm round material with the cross piece approximately 400mm long and a leg about 600mm long, now if you leave the three jaw attached and the back gear locked the tee bar can be fed through the headstock and locked into position using the three jaw, lifting of the headstock end is then much easier when a firm hold can be maintained, the whole lot is then easily lifted by two chaps, the weight being reasonably distributed.
                                          Bob Youldon
                                          #202193
                                          Roger Vane
                                            @rogervane67137
                                            Mine came home on the back seat of a Triumph Herald – that dates both of us.
                                            #202196
                                            roy entwistle
                                              @royentwistle24699
                                              Roderic That man in the ME advert worked for a firm in Cleckheaton I bought a ML7S with gearbox He carried it about 40 yards from his car into my workshop and lifted it onto a bench He also carried my old ML7 away I casn't remember his name
                                              Roy
                                              #202200
                                              Ajohnw
                                                @ajohnw51620
                                                Posted by Neil Wyatt on 27/08/2015 13:45:49:
                                                Unicorn grease.
                                                Maybe they should have used that in the bearings as well.
                                                Hope the welder that was mentioned was certified, frownmaybe some might feel I shouldn't use the word certified as it might be taken as a freudian slip,
                                                Edited By John W1 on 27/08/2015 16:39:49
                                                #202206
                                                Bazyle
                                                  @bazyle
                                                  Lathes are very prone to tipping forwards and breaking the handwheels. I suggest a precautionary 2ft plank going front to back bolted to the feet. Then you could winch it up a couple of planks if it started at ground level.
                                                  Earlier this year I sneakily moved to the tailstock end when picking up my Drummond B (120lb?) as the seller looked reasonably young. Turned out we were the same age but as he was a steelworker I figure he was still more able to take the heavy end. Unloaded it on my own with my two trusty planks, plus some ingenuity.
                                                  The biggest problem I have is the 9 in boot lip. An estate would be so much easier than my Nippa but wouldn't do 60mpg. Last year I had to take all but the drivers seat out to transport a pillar drill surprise
                                                  #202222
                                                  Ray Lyons
                                                    @raylyons29267
                                                    I have moved ML7s and S7s a few times. Now I use a piece of hardboard or better still a piece of board with a plastic surface. This is placed in the estate car floor and then the lathe, is put on a two wheel sack truck on top of a smooth board. I then reverse the truck onto the back of the car so that the handles rest into the boot. This then allows me with a bit of help, to lift the wheels of the truck up to boot height and then slide the lathe into the car. It is quite easy if the surface of the plastic or hardboard is wiped over with an oily rag before starting. Lifting the lathe onto a bench is best done with a car engine crane, readily available from the hire shop, although I have rigged up two gantries made of 4×2" timber and threaded rod to hoist and get into position, a long process but safe.
                                                    #202233
                                                    The Merry Miller
                                                      @themerrymiller
                                                      Roger,
                                                      Another word of advice.
                                                      Before you or any helper with you attempt any manual lifting or manipulation make sure that you clean off any oil that may be lurking on the surfaces in the zone of lifting.
                                                      I did not and when my son-in-law and I went to lift my Myford into the garage/workshop, my son-in-law (who could lift the side of a house) nearly lost it holding the headstock end because I hadn't cleaned the oil from it.
                                                      Just beware!!
                                                      Len. P.
