Dusty,
I assume you bought an Invertek vfd?
I'll try and keep this simple….
You need for wiring the motor…..
2 x 20mm stuffing glands, one for the motor and one to go into the control for the motor cable.
1 metre of 1.5 mm 4 core cable ( 3 phase and earth). Some would say it needs to be screened, but for the length between the motor and vfd, I wouldnt bother. ( I didnt when I did mine, dont suffer from any kind of radiation or from any knd of spurious trips)
Remove the motor terminal cover and make the connections as per the diagram called Delta, by moving the metal straps so they are all in a row vertically.
Next, screw the 20 mm gland into the motor terminal housing. Strip the cable back and ideally use crimp lugs, secure the three phase wires to the terminals marked U,V and W. Connect the earth wire to the earth connection in the box.
Mount the inverter inside the control box, I used a short piece of din rail rivetted to the back.
Fit the other 20mm gland, feed the motor cable into the box, strip back the free end and again with crimp lugs, terminate into the U,V and W terminals on the inverter. Connect the earth wire to the terminal marked PE.
The Mains wiring that went to the two connectors marked L on the old speed control board now need to go to the respective terminals on the inverter…( I am assuming you havent stripped out any of the original wiring), marked L1/L and L2/N.
You should connect a seperate Earth lead from the control box GND to the terminal marked PE on the inverter.
Do not omit the above step!
That concludes the 'mains ' wiring side of things.
You can test the motor rotation now, add a wire link to terminals 1 and 2 on the inverter, switch on your lathe, press the Start button in the keypad on the inverter and using the Up and Down arrow keys the motor should speed up and slow down…Check the motor runs clockwise when viewing the motor shaft…..If it doesnt, post up on here…
I think thats enough for now for you to be getting on with….
Switch everything off and have a cup of tea/glass of wine/ shot of tequila whatever you drink….and toast your success!
Edited By John Rudd on 05/03/2017 18:42:43
Edited By John Rudd on 05/03/2017 18:43:45
