I have the Warco 250V-F & changed the 4 way tool post to a QCTP of the Dickson type, a clone by Bison' I have found this works very well, I had to make a new compound slide stud as the original was of questionable material & assembly. I now have 18 holders from various sources ( mostly from RDG & Warco at the exhibitions, usual disclaimer ) they all fit neatly & clamp up securely… some don't so check if you can.
For rigidity I have the tool post set back on the compound slide so the tool holder sits above the compound slide base & dovetails & not overhanging so the cutting forces bear down onto the compound & top slides, certainly makes a difference. I have also made a new compound slide gib key as the original was an abortion of a piece of MS plate that didn't bear any resemblance to a gib key, also ensuring the gib adjusters are snugged up. I have also adjusted the rear saddle SHCS so the saddle has 'just noticeable' drag feel to it as the saddle is moved, this will help to remove any 'lift' at the rear of the saddle. I still have a slight oil leak from the saddle gearbox but as I only top it up every couple of months it's one of those 'round to it ' jobs.
Tool post set back… it still clears the chuck…
The original gib key…
New gib key…
I also made a larger knurled ring for the compound slide dial as the original was far too small for my 'chubby' fingers…
Hope the above helps.
George.
