warco 220 wiring
warco 220 wiring
Home Forums General Questions warco 220 wiring
Viewing 2 posts - 26 through 27 (of 27 total)
  • #185934
    kevin large
      @kevinlarge76611
      hello dave I seem to have a similar problem to the 1 you had did you keep any of the diagrams etc
      is your lathe an early model
      regards kevin
      Les Jones 1
        @lesjones1
        Hi Kevin,
        Your problem is not similar to Dave's. Dave's reversing switch was wired in an unusual way with 5 wires giong to the motor. Yours is the straightforward way with 4 wires between the reversing switch and the motor. If you had the same problem as Dave then all the information required is contained in this thread.
        Les.
