“Vintage” Dial Gauge
Home Forums General Questions “Vintage” Dial Gauge
  • #196057
    Barry Forrest
      @barryforrest38823
      I recently purchased what was described as a "Vintage" Dial Gauge, an ACE S1 Rustless, manufactured by Engineering Products Limited London. It looks almost new, very shiny (Nickle or Chrome plated perhaps). It's a "curio" in so far as it will be sitting on a base amongst the engines and other bits and pieces that have come out of the workshop.
      Out of curiosity I will probably test it although I don't intend to use it. My problem is searching on the internet has produced no information on either the Dial Gauge or the manufacturer.
      Can anyone provide any information about this piece of equipment?
      Thanks
      Barry
      Edited By Barry Forrest on 07/07/2015 17:29:56
      Barry Forrest
        @barryforrest38823
        Help with Information
        #196058
        Barry Forrest
          @barryforrest38823
          #196064
          NJH
            @njh
            Why a "curio" Barry? As far as I can see it's a pretty standard dial gauge – I have two similar although of different makes. Very useful ( essential?) when setting up work on machines – for example work in the 4 jaw chuck on the lathe.
            Norman
            #196068
              Engineering products Limited
              Status: Dissolved 08/11/2011
              Date of Incorporation: 21/05/1932
              Country of Origin: United Kingdom
              Looks like you just missed the opportunity to ask them…
              Phil Whitley
                @philwhitley94135
                Provided it isn't damaged, and it looks unused, or well looked after, use it, and be amazed at how much better it is than the modern ones!
                Phil
                #196096
                John Haine
                  @johnhaine32865
                  A friend once proudly showed me the brass blow lamp he'd just bought from an antiques shop, polished and sat on his living room shelf. I didn't dare tell him you could still buy them new but much cheaper from the local hardware store….
                  #196116
                  Barry Forrest
                    @barryforrest38823
                    Thanks to all those who responded to me about the ACE Dial Gauge.
                    #196121
                    CotswoldsPhil
                      @cotswoldsphil
                      Here is an S3 (looks to be a little larger dial than the S1) used when required to centre material in the 4jaw etc. It has worked perfectly for the last 35 years and will most likely see me out.
                      Phil
                      Edited By CotswoldsPhil on 08/07/2015 09:59:39
