Vertex 6″ rotary table
Home › Forums › Help and Assistance! (Offered or Wanted) › Vertex 6″ rotary table
  • #337649
    john fletcher 1
      @johnfletcher1
      Help needed to reassemble and adjust my rotary table. Some time ago I think there was a detailed article on the doe's and don'ts when reassembling these table. John
      #33140
      john fletcher 1
        @johnfletcher1
        #337655
        SteveM
          @stevem36008
          Hi John,
          Stefan Gotteswinter has a very interesting series of videos on an identical table which should be linked below. Although to be fair pretty much everything he outputs is interesting.
          Improving the vertex rotary table
          Hope that helps
          Steve
          #337695
          Howard Lewis
            @howardlewis46836
            Just DON'T trust the chart that comes with it! It contains errors and omissions, (Eight by my count; never checked beyond 100 divisions).
            Certainly the one for 13 divisions is wrong (as I found to my cost!) Some of the errors are probably from reading a Zero as a 6 or an 8.
            If in ANY doubt, DO check by calculating!
            #337698
            john fletcher 1
              @johnfletcher1
              Thank you Steve, youtube is my next port of all. Also thank you Howard annoying when you finish up with either a thin tooth or one missing altogether. I'm in the process of an Arduino conversion. Hopefully no more counting the turns, then the phone rings, I have little black board but my memory is not what it used to be. John
