Going back to the original question, I have owned/do own the following:
Imperial 0-1″ micrometer, 0.001 thou
Metric 0-25mm micrometer, resolution 0.01 mm
Metric 25-50mm micrometer, resolution 0.01 mm
0-150mm Vernier caliper, resolution 0.05mm
0-150mm dial caliper, resolution 0.02mm
0-150mm/0-6″ digital caliper, resolution 0.01mm/0.0005 thou (Digical 1)
0-150mm/0-6″ digital caliper, resolution 0.01mm/0.0005 thou (Digical 2)
0-150mm dial caliper, resolution 0.01mm
When I realised that there were various discrepancies, I bought the 25, 50 & 75mm Mitutoyo micrometer standards and set about checking everything. Obviously I am aware that touch can vary, as can temperature & dirt, so I attempted to eliminate as much as possible, eg by taking multiple readings.
Of these, digical 2 was found to be inaccurate whilst digical 1 always read slightly high. Or was it low? In any case, with a reading tolerance of ± 1 digit and 0.01mm, I did not think much of them. And then when I found the rate at which they ate batteries, I stopped using them.
The 0.02mm dial caliper was found to be consistently reading low, so was given away.
The 0.05mm Vernier caliper was found to be dead on. As was the 0.01 dial caliper by Starrett which was bought to replace the 0.02mm dial caliper and the two digital calipers.
The metric micrometers were found to be either dead on or reading +0.005 mm at maximum reading. Even the imperial was reasonably accurate. With these, knowing the maximum variation, I compensate as necessary, eg at 12.5mm I add 0.0025mm. Ok, I know it may not be correct, but it is the best I can do.
As has been said, there is the problem of taking accurate readings with the narrow jaws of the calipers: in fact, it was this difficulty which caused me to get out the micrometer and thus discover the various discrepancies. I now use, firstly the 0.05 vernier for general purpose measurements followed by either the micrometers or the Starrett dial caliper as seems most appropriate.
I still have the digital calipers, and do occasionally use the better of the two, but only when the measurement is not required to be particularly accurate.
Anybody want an inaccurate Workzone caliper from Aldi?
Peter G. Shaw
