Unknown object
Unknown object
Home › Forums › Beginners questions › Unknown object
  • #419897
    Paul Barter
      @paulbarter66156
      Hello all,
      Please does anyone know what the purpose of this thing is?It seems carefully made witha gimbal arrangement that has provision for locking one axis with a thumb screw, the other axis has small adjustment screws to adjust end float,there is a collett chuck on the gimbal. The larger clamp screw has sharp point on the outer surface! and the connecting strap is spring steel.
      Any suggestions gratefully received.
      Paul
      #9759
      Paul Barter
        @paulbarter66156
        #419915
        magpie
          @magpie
          It's a fingymajig.
          #419929
          DC31k
            @dc31k
            I think it is a precursor to a dial test indicator, used for centring up work in a four jaw chuck.
            There is a long, slender rod that goes through the collet. The end of this locates in a centre drilled in the work. The length of rod between holder and workpiece needs to be relatively short; the free end relatively long to amplify any out of trueness. When the free end stops wobbling about, the work is true.
            #419934
              Posted by DC31k on 20/07/2019 06:59:26:
              Brilliant deduction … I'm sure you are correct yes
              It merits a cross-reference to this thread: **LINK**
              https://www.model-engineer.co.uk/forums/postings.asp?th=143609&p=1
              Edited By Michael Gilligan on 20/07/2019 07:40:34
              #419937
                Possible but all the ones I have seen the rod goes straight through so you can compare it's movement against a tailstock ctr. This item looks like the long rod would be at 90deg to the point and wave about in the air?
                #419938
                Paul Barter
                  @paulbarter66156
                  Thanks to you all for such quick responses. Any ideas as to why it is supplied with an elaborate means to lock an axis on the gimbal? I thought a wiggler needs freedom in all directions and one end must be a datum ie on centre in either a tailstock chuck or mill Collett. The sharp point on the clamp screw is a puzzle, unless it was designed and used by a masochist!
                  Paul
                  #419939
                  Paul Barter
                    @paulbarter66156
                    Jason you beat me to it, I agree it probably is not an ancient wiggler like Tina T
                    #419940
                      Posted by JasonB on 20/07/2019 07:52:20:
                      If you set those pivots appropriately, I'm pretty sure it could do as the others
                      If you have time, Jason, break-out the 3D CAD please …
                      MichaelR
                        @michaelr
                        It could be something to do with tying fishing flies !!
                        Mike.
                        #419950
                          A Starrett tool, with 'a close family resemblance' I would say: **LINK**
                          https://www.practicalmachinist.com/vb/general/starrett-mystery-tool-141785/
                            DC31k
                              @dc31k
                              Posted by Paul Barter on 20/07/2019 07:58:41:
                              Thanks to Michael for digging up the PM thread. To quote from post 14 of that one:
                              “The indicating needle is 12 ¾ inches long when jointed together, magnifying greatly the slightest movement at the indicating point, and being in two sections it may be carried in the mechanic's kit conveniently.
                              The needle also passes through the ball, having a split stem, forming a chuck for holding it, and it may be adjusted to any length. The ball is pivoted to form a universal joint but may be instantly converted into a single joint for vertical motion by merely tightening the knurled knob, adapting it for inside and outside surface contact. A steel ball about .175 inch in diameter slips over the point for inside work. . . .”
                              So you need to make it uniaxial if not using with a centre-punch mark.
                              Very clever, those old boys.
                              #420000
                              Ian S C
                                @iansc
                                I'v never seen one like that, but many years ago I made one, the rod I used was a double ended steel sock knitting needle about 8" long.
                                Ian S C
                                #420002
                                Paul Barter
                                  @paulbarter66156
                                  Thank you all for taking the time to educate me yet again. Thank you especially Michael Gilliian, you have nailed it, now to find a silver steel rod.
                                  regards to all Paul
                                  #420015
                                  duncan webster 1
                                    @duncanwebster1
                                    Posted by Paul Barter on 20/07/2019 13:44:54:
                                    regards to all Paul
                                    Why silver steel, no strength required
