turning tapers
turning tapers
Home › Forums › General Questions › turning tapers
  • #22998
    geoff
      @geoff
      jto taper
      #137419
      geoff
        @geoff
        I would like to turn a taper using the topslide on my lathe the taper is to fit my jto taper chuck could some one tell me how to work out the set over angle please
        Regards geoff
        #137422
        Thor 🇳🇴
          @thor
          Hi Geoff,
          when I turn short tapers I first clamp the chuck in the 4-jaw and center it, then put a Dial Test Indicator on the topslide and adjust until I can move the topslide without the indicator moving. Then mount the work and turn using the topslide. Don't finish turn, but test first by bluing.
          Thor
          #137423
          Ady1
            @ady1
            There are a few threads in here about taper turning, use the search function
            There are a few solutions
            My own solution on a hobby lathe was to use a dial indicator fixed to the cross slide and measure the taper over a fixed distance travelled by the leadscrew
            Measure your taper this way, then set the topslide the same way with the dti fixed to the lathe bed
            Fiddly, but worked well for MT1 stuff
            #137426
            Gary Wooding
              @garywooding25363
              Just one thing to add, make absolutely certain that the tip of the DTI is on centre hight, or use an "elephant foot" on the DTI.
