Hi guys,
I'm trying to plan the machining operations for an Elmers 25 wobbler.
The crank disk is a bit of mild steel, a bit less than an inch across. To make this, I have a length of steel bar the right thickness – I plan to mark it up, cut off a square length the right size – drill the crank-shaft hold in the middle, then mount it on an arbour and turn it down.
The bit I'm not sure of is if this will work :^)
What I will end up with is a square shape that I've got to knock the corners off to turn it round – but the mounting will be an bolt on an arbour held in a collet. I'm pretty sure this will spin in the arbour rather than cut as the tool hits the corners of the work piece…
Never having used (or made) an arbour before I've no idea how securely it will grip the work piece…
Is there a better way of making this piece that doesn't involve buying more material (round BMS rod of the right thickness)? (or am I making a problem for myself that $10 will solve
cheers. Jerry
