Posted by richardandtracy on 25/03/2018 16:57:33:
Posted by Martin Dowing on 25/03/2018 10:57:48:
This 1050 grade is widely available and at least in my opinion it is good for nothing.
Martin
'This very useful for sheet metalwork with 0 corner radius. Best if sheared. Easily formed, cut etc.. Not wildly useful aside from that, I admit.
Your idea of a microwave furnace is interesting. I have not done anything that sophisticated. I made myself a little furnace using scrap stainless ducting and lined it with £2 of concrete. It's now needing re-lining after 15 years. I have used coal, charcoal and pallets as fuel. At best I can melt 2lb of aluminium in15 mins. With the microwave, if you have much metal in the crucible, there must be a concern over radiant heat igniting something – sure I'm telling granny how to suck eggs, but domestic microwaves are not meant to hold something that hot. The heat radiated from the crucible when withdrawn from my furnace is really quite astounding.
Richard.
You need to insulate microwave walls and door with light heat insulating material which is used also for thermal insulation of fireplace. this material is cheap and very easily formed.
Alternatively you can purchase similar looking material used in furnaces.
Both are wonderful heat insulators.
You *must* ensure that your product is microwave transparent, eg it does *not* get hot when stuffed up to microwave. After few minutes it may get a little bit warm but nothing more than that. In any case avoid running microwave on no load for more than 2-3 minutes or you may damage magnetron and other circuitry.
To join pieces of insulating material you may use an adequate fire resistant cement. Cement also must be (when dry) microwave transparent, test it as your insulating material. Appropriate cement is alumina based and certainly *not* zirconia based as the latter will absorb microwaves and get very hot and it is not what we want.
Make sure that thermal bridges are absent, eg that thermally insulating layer is protecting entire interior and door. 25mm of meticulously fitted insulation from all sides will do if you are not aiming above copper or gold (1100*C) and do not intend to run extended sessions, few hours long. Otherwise apply 50 mm thick insulation.
You must provide for pressure equilibiation measures.
Now you need a crucible and this should *not* be microwave transparrent. The best (and cheap enough) are *carborundum* (silicon carbide) crucibles and preferable variety is one nitride bound but others are also good.
Another and more expensive option are those made of zirconia.
You will recognize suitable crucible by observation that it gets very hot once stuffed to microwave. If left too long it will get red hot and damage not thermally insulated microwave. Fire and property damage might result.
To reduce risk of fire it is also of paramount importance to use new or exceedingly well cleaned up microwave.
Now fill scrap metal to your crucible and stuff it to microwave. My initial trials were done in block of mentioned insulating material and silicon carbide crucible. Microwave is not lined up with insulation like described but a block of insulating material encasing crucible from all sides is good enough for prove of concept experiment.
20 grams of scrap silver was smelted within 20 minutes in 800 W microwave. Beauty of this setup is that most of microwave energy is going only into crucible and its load.
If you want to use microwave as a muffle, stuff few lose silicon carbide heating elements in. You will get hot chamber this way.
There is much more to it, above are explained only basics sufficient to get one going.
I may write something about it in the future, once some basic work to develop this tech is done. For example flimsy plastic parts in door will need replacing with something sounder, inlet and outlet of inert gas is to be installed etc. Interlocks switching off power upon opening of door should be kept and after any modifications of the oven one must ensure that microwaves do not leak out etc.
Some basic setups working with household microwave sufficient to melt a sample of glass are sold on Amazon. Search for "microwave kiln".
I am developing substantially better product than this.
Martin
