Posted by richardandtracy on 25/03/2018 10:39:10:
Why not consider a 2 piece pulley & pin together? That way the plate need only be slightly above the width of the belt.
Aluminium grades – which type do you find difficult to machine? Many grades are gummy with tools aimed at steel. Use of the right lubricant or carbide inserts makes the stuff machine well. One of the engineering skills with aluminium is using the right grade in the right place. Something like 1050 is the metallic equivalent of cream cheese, and works well where you need cream cheese. Same as with steel, you'd not use a hardened bit of silver steel where mild would do, and vice versa.
Richard.
This 1050 grade is widely available and at least in my opinion it is good for nothing.
I do not have any difficuty in machining it but parts made of it do not last long, so they are best if not made at all.
I love 7xxxx grades as some of these are very good but it is not easy to get them. Silumins are OK but until I have adapted my old microwave for smelting them, they are not usable for me.
NB. converting microwave into smelter is an interesting project of its own and not costly either. I can already smelt 10-20 grams samples of silver there but some more permanent thermal insulation of walls and door is needed for more sensible quantities. Bonus is that it could allow for smelting under argon to produce quality melts if necessary or should be usable for brazing in inert gas, eg there won't be scaling, I hope.
Martin
