Traction Engine Lamp Article Drawing Errors
Home › Forums › Drawing Errors and Corrections › Traction Engine Lamp Article Drawing Errors
Viewing 2 posts - 1 through 2 (of 2 total)
  • #38776
    Jeff Dayman
      @jeffdayman43397
      #132899
      Jeff Dayman
        @jeffdayman43397
        In issue 4463 pg 295 the "wick adjuster" detail shows a .25" dia x .064 flange at the right end of the part. Photo 82 on the following page shows this flange on the inboard (left) end of the part. It looks like the flange must be on the left end as in photo 82 for assy to be possible into the "burner" part. It would be better if the details in Fig5 pg 295 were drawn at a larger scale. Bad job by the illustrator.
        On the "burner" detail the horizontal dimension from centre of the part to centre of the .188 hole is missing.
        This is an excellent series of articles which I have enjoyed, although I have no immediate plans to make these lamps. Congratulations to Mr.Couchman on a fine series.
