Todays DUMBO award
Todays DUMBO award
Home Forums The Tea Room Todays DUMBO award
  • #403610
    Former Member
      @formermember19781
      Former Member
        @formermember19781
        Todays DUMBO award.
        #403611
        Mike Poole
          @mikepoole82104
          Just turn the tool upside down smiley
          #403612
          Paul Kemp
            @paulkemp46892
            That would do it! Did something similar with a home made spot facing cutter in the mill! Realised I had ground the bit the wrong way round, reversing the spindle made a significant difference sad. It happens lol.
            #403620
            Brian G
              @briang
              I wanted to reduce the diameter of a spigot but the part was too big for the lathe. "I know, I'll use the boring head" I thought. Set the tool facing inward, put the mill in reverse and got on with it. When I finished the job I removed the head from the arbor and started sweating. It was only hand tight but luckily hadn't unscrewed.
              #403623
              Brian Oldford
                @brianoldford70365
                Posted by Mike Poole on 04/04/2019 18:17:58:
                That's the "putting on" direction. cheeky
                #403624
                Jon Lawes
                  @jonlawes51698
                  If it makes you feel any better I've done the same thing. I don't remember having set the lathe to reverse but I know it took me ages to work it out…
                  #403634
                  mark costello 1
                    @markcostello1
                    Whew, for a minute I thought I was going to get nominated for an award, thought no one was watching.
                    #403636
                    Boiler Bri
                      @boilerbri
                      Nice one for owning up 👍👍👍
                      #403665
                      Sam Stones
                        @samstones42903
                        My claim to ‘Jumbo of the day’ goes back many years to when I decided I needed to drill a ¾" hole under the corner cupboard in the kitchen. It was a real sod to reach and I struggled for ages thinking that the wood bit was blunt or I’d hit something hard.
                        Like Bill, I stopped for a cup of coffee, while I gathered my thoughts.
                        And, like Bill, I noticed that the battery driven drill was running …… you guessed it ………. backwards. crying
                        Sam smile d
                        #403667
                        I.M. OUTAHERE
                          @i-m-outahere
                          How many times have you put a hacksaw blade on backwards and only realised it when it wont cut blush , i worked out the other day that coping saws work better if i put the blade on so it cuts pulling the saw towards me – takes The springiness of the frame out of the equation !
                          i was turning a piece last weekend and it wasn’t going well ended up I hadn’t tightened the clamping lever on my QCTP . I was also using the tailstock centre to set the tools on centre but for some reason it kept changing ,one tool would be too low next tool on centre and it ended up that the centre was just sitting in there and every time i moved the tailstock the centre changed position a small amount !
                          There are others but i feel i have shamed myself enough for one day !
                          Murphys law for model engineers :
                          if it takes days or weeks to make a part it will only stuff up on the last operation !
                          If it has to be shiny you will polish it to perfection then drop it damaging the finish !
                          if it is to be painted you will choose a day of low or little wind but this will change by the time you finish painting it and a hurricane will appear out of nowhere !
                          The more determined you are not to lose something the quicker it will disappear !
                          All springs can fly and always further than you think !
                          and the list goes on .
                          #403674
                          Hopper
                            @hopper
                            I worked with Swiss engineers who always fitted hacksaw blades "backwards" because thats the way they do it there. They swear it works better.
                            #403679
                            AdrianR
                              @adrianr18614
                              Ah drills running backwards, that reminds me. I had to drill a hole in a CI soil pipe for a new sink. I bought a hole saw and started. Pilot went in easy, but the saw just wouldnt cut, pushing hard made it cut slowly. After a long time I stopped for a cupper. Looking at the worn the teeth I realised something. The blade had been welded on backwards. Flipping the drill into reverse and the hole was finished in seconds.
                              #403685
                              Nicholas Farr
                                @nicholasfarr14254
                                Hi. yea, I've done the battery drill one, even when it's in full view.
                                Regards Nick.
                                #403779
                                Sam Stones
                                  @samstones42903
                                  And today, my claim to the 'Dumbo of the day' award comes from seeing that I referred (with apologies) to JUMBO.
                                  How daft is that?
                                  Sam smile d
                                  #403797
                                  Chris Trice
                                    @christrice43267
                                    Yep, I've done the cordless drill in reverse thing too except I was trying to push an apparently sharp 10mm drill through a piece of steel. Made no difference how hard I pushed for two minutes before the penny dropped.
                                    #403818
                                    vintage engineer
                                      @vintageengineer
                                      You can buy lefthand drills. I have a set but they are kept well away from my other drills!
                                      #403854
                                      Howard Lewis
                                        @howardlewis46836
                                        As an Apprentice, once ran a face mill in reverse, and wondered why it didn't cut well.
                                        Much more recently, modified the lathe to halve the feed rate. Trying to cut a 1.5 mm pitch thread, but could not get it right. Reason: obsessed with the 3 setting, so set 3 on the Norton box instead of the correct setting. Funnily, once the proper setting was used; the nut screwed on. Strange?
                                        "The man who never made a mistake, never made anything"
                                        #403857
                                        Russell Eberhardt
                                          @russelleberhardt48058
                                          Posted by Hopper on 05/04/2019 07:49:27:
                                          I've done that for years. Try it! I think it's because the centre of push on the handle is higher than the blade teeth. So if the teeth catch the push makes them dig in more. If pulling to cut the pull tends to lift the teeth if they catch.
                                          . . . or perhaps it's because I have Swiss ancestors smiley
                                          Russell
                                          Edited By Russell Eberhardt on 06/04/2019 11:07:03
                                          #403860
                                          KWIL
                                            @kwil
                                            That is why fret saws work better teeth down and Japanese wood working saws are all draw saws, thin and pulled towards you.yes
                                            #403862
                                            Andrew Tinsley
                                              @andrewtinsley63637
                                              My claim to fame must beat everyone else. I was putting in a sink and assorted kitchen units. I had a pipe (cold water) running down the wall, but proud of it. So I decided to make a channel in the wall and bury the pipe. I then thought I could run an electric cable in the channel. All was then plastered up, so far so good.
                                              I had to fasten the sink unit base and units to the wall. So I put a horizontal batten along the wall. I drilled the fixing points for rawplugs carefully marking each position before hand . I even marked where the water pipe was.
                                              You guessed it I drilled along the line of marks including that which marked the pipe. There was a flash and a bang and I pulled the (thankfully double insulated) mains powered drill out of the hole and got a jet of water straight in the face!
                                              So don't cut corners as I did. The drill was quite interesting the carbide(?) cutting edge was quite fused!
                                              Andrew.
                                              P.S. How is that for being honest and admitting to Wally status?
                                              #403864
                                              Former Member
                                                @formermember19781
                                                #403879
                                                Andrew Tinsley
                                                  @andrewtinsley63637
                                                  Thank goodness I am not alone in the Wally stakes! There are so many experienced and erudite people on this forum, that I never expected my 1st class Wally status to be challenged!
                                                  Andrew.
                                                  #403901
                                                  Dave T
                                                    @davet19446
                                                    Junior hacksaw blades definitley cos it tensions the frame when cutting – never tried it with biggerindecision
