Timken bearing
Timken bearing
Home Forums General Questions Timken bearing
  • #306338
    sean logie
      @seanlogie69385
      Been trying to find spindle bearings for the Centec2 mill and not having much joy . Sizes are as follows …
      Rear bearing …
      Od…2.240" ,56.92mm
      I'd… .749" 19.03mm
      W… .63" 15.9mm
      Front bearing
      Od… 2.240" 56,92mm
      id… 1.125". 28.58mm
      W… .630 15.9mm
      I'm assuming they're Imperial .
      Sean
      sean logie
        @seanlogie69385
        #306339
        John Reese
          @johnreese12848
          Aren't there numbers stamped into the cups & cones?
          #306346
            Is that the overall width of width or one cup?
            if just the outer cup at 0.625" then the rear looks to be 1775-1729 Front 1988-1930 though there are a few other option sdepending on overal width see here
            Just search those numbers and you get something like this
            Edited By JasonB on 09/07/2017 19:38:14
            #306359
            sean logie
              @seanlogie69385
              Here’s what’s on the bearings ….
              Outer 1930 2-0
              Inner 1985 1-6
              Outer 1729 1-6
              Inner 1775 4-6
              Sean
              #306362
                Slightly different spec on one of them to what I gave, follow the second link to buy them or just put the codes as I wrote them into google.
                #306371
                Bob Rodgerson
                  @bobrodgerson97362
                  If they are Imperial/old bearings try the Vintage Bearing Company. He deals mainly with cars & Motor Cycles but might well be able to help.
                  #306442
                  sean logie
                    @seanlogie69385
                    Phoned them this morning Bob and they have them in stock 👌
