Why stainless ??
If you want appearance and / or corrosion resistance then ‘ Nickel Silver ‘ could be used .
If you want strength then HS Brass or similar could be used .
There are certainly many material choices available which may be easier to work than stainless steel .
As regards tapping small threads in difficult materials you need good quality sharp taps such as TiN coated HSS ones from a reputable maker .
Where available serial taps work much better than traditional taper/second/plug .
With serial taps each successive cut is quite small and risk of non-cutting and broken taps is reduced .
Extreme pressure lubricants help a lot but can be difficult to remove totally – may need components to be boiled in detergent or soaked in solvent if cleanliness matters .
Just a final note on costs – ? 5-60 each is quite reasonable . It may not seem so to people on this site but it’s peanuts by industrial standards of pricing for small numbers off bespoke components .
Probably better to spend your money on a small lathe and some tooling .
Plenty of cheap imported lathes available and much cheaper and much more fun to make things yourself anyway !
Regards ,
MikeW
Edited By MICHAEL WILLIAMS on 07/01/2014 15:54:01
Edited By MICHAEL WILLIAMS on 07/01/2014 15:56:26
