Threaded rod into brass tube
Home Forums General Questions Threaded rod into brass tube
  • #366408
    Michael O’Callaghan
      @michaelocallaghan36064
      I have an M18 mild steel tube and wanted to put a threaded rod with a threaded Rod Connecting Nut to fit snugly inside, but I don't want to buy the wrong size and have to return it.
      Could some one please tell me what size threaded rod I should order.
      Thanks
      Michael O’Callaghan
        Didn’t know the right size
        #366410
        pgk pgk
          @pgkpgk17461
          The question cannot be answered without knowing the wall thickness and therefore the internal diameter of that tube.
          pgk
          #366411
          peak4
            @peak4
            I assume M18 refers to 18mm Outside Diameter, but to work out which nut would fit, you need to know the Inside Diameter, or at least the wall thickness of the tubing to work it out
            This Link will take you to a table of Across Flat/Across Corner dimension of metric nuts. There are many similar tables on the net for other threads/spanner sizes.
            So say your tube is 18mm OD wall thickness 1.5mm then ID is 15mm.
            M8 would be too loose @ 14.3mm M10 too tight @ 17.8mm
            Your only option would be to look around for a different thread, or file a bit off each of the corners of the nut.
            I'm assuming you don't have access to a lathe to do the job.
            Bill
            #366413
            Weary
              @weary
              If I have understood your question correctly the following may assist–>
              This table gives the standard metric nut dimensions across the corners, you can check which will best fit your tube and thus which threaded rod will be most suitable. Or, alternatively you could purchase tube to fit a chosen size of studding and connector. Your connector could of course be lightly machined to reduce the across the corner dimension whilst retaining enough flat to apply whatever torque you may require.
              I am assuming that your studding connectors retain nut dimensions as this table would indicate – excepting the length which should be three times the thread diameter!
              Phil
              And Peak4 types far faster than me!! *chuckles*
              Edited By Weary on 09/08/2018 10:27:41
              #366414
              Martin Connelly
                @martinconnelly55370
                Why do you need a coupler in the tube? You can get threaded rod studding in 3m lengths.
                Martin C
                #366421
                Hopper
                  @hopper
                  Is this still to make a mad tool to pull wire tight to hold wire mesh to fence posts, to keep cats out of your garden, like in your last thread? I've found that twisting wire with pliers is plenty good enough to keep cats from getting through a mesh fence. Also using cable ties works well.
                  8mm threaded rod and joiner nut should fit.
                  Edited By Hopper on 09/08/2018 11:18:22
                  #366446
                  Nick Hulme
                    @nickhulme30114
                    Posted by Michael O'Callaghan on 09/08/2018 09:55:42:
                    Is that M18 Coarse, Standard or Fine Pitch?
                    #366461
                    Hopper
                      @hopper
                      Posted by Nick Hulme on 09/08/2018 12:35:49:
                      A fine pitch will provide more force per turn than a coarse one, allowing the OP to pull his wire harder.
