There is a compendium of thread data here in a spreadsheet form:
https://journeymans-workshop.uk/downloads.php
You can use it to calculate (an approximation*) of the helix angle (ha) of the threads.
ha = arctan(pitch/(2*major dia)
Note that it is easier to use the metric values of major dia. and pitch from the table. If you use imperial values, you have to convert tpi to pitch.
Sort the spreadsheet by calculated helix angle.
To me, the results were surprising: the lowest helix angle is something like 6" BSP – understandable because BSP is a constant pitch series above 1".
The steepest helix angle is 1/8-26 brass, which we normally think of as a fine pitch thread. Above that one is some very high number (greater than 20) BA threads.
Before I did this, my money would have been on 1/4 BSW as it is a coarse pitch for its diameter, but I was nowhere near.
* I believe helix angle is more correctly calculated at the pitch diameter, but for this exercise, we are only doing a comparison.
