Thread on front forks on a Raleigh bike
Home Forums General Questions Thread on front forks on a Raleigh bike
Viewing 25 posts - 1 through 25 (of 34 total)
  • #546716
    mike barrett 1
      @mikebarrett1
      I have a 1990's Raleigh bike which has RST suspension fronts forks. The forks have fallen apart (inside springs rusted away) and I dont think I can repair them,
      I want to replace then but cant anything similar. The steering shaft from the forks is140mm long and have a threaded end to retain the top bearing and are 38.6mm (1 1/8&quot diameter. The handle bars use a quill fitting inside the shaft.
      Most forks are now plain with a clamp to hold the bearing. I cant find a threaded shaft version that is only 140mm long so was wondering if I could buy a plain version and then cut the shaft down to size and cut a thread on it.
      The question is what thread is used on the shaft and where can I buy a die for it?
      Any suggestions welcome. I am trying to keep as much of bike original if possible.
      Thanks Mike
      mike barrett 1
        @mikebarrett1
        #546717
        Chris Evans 6
          @chrisevans6
          It is my belief that 1990s bikes are a lottery for thread due to so many parts being made in the east. I have made a new stem for one of my old motorcycles, screwcut at 26 tpi and brazed into the lower yoke.
          #546724
          Bo’sun
            @bosun58570
            Good morning Mike,
            Before you get too involved, check that your selected plain steerer will accept the quill.
            #546734
            mike barrett
              @mikebarrett73459
              Posted by Bo'sun on 24/05/2021 09:03:23:
              Good morning Mike,
              Good point! One of the problems is finding any technical (sizes) details of what being sold on line.
              I think I need to find an old school bike shop to visit.
              Also thinking of going back to see if I could rebuild the original forks. The springs have rusted badly but I should be able to replace them. There are a couple of plastic bushes that are worn but i could make new ones.
              the part I dont understand is what stopped the forks coming apart, They now fall apart. There was no bottom fixing as far as I could see unless it has rusted away. I cant find a manual for the original forks, The company used to publish manual but was taken over and the manual doesnt seem to be available any more.
              regards Mike
              #546745
                Quite common to have to cut down the steerer on a pair of forks be they old style or new, most likely 1 1/8 x 26tpi see here
                #546750
                Bo’sun
                  @bosun58570
                  Sheldon Brown. Always a good source of reference.
                  #546781
                  mike barrett
                    @mikebarrett73459
                    Posted by JasonB on 24/05/2021 10:03:12:
                    thanks excellent site!
                    mike
                    #546785
                    Bo’sun
                      @bosun58570
                      Hi Mike,
                      I'm sure there will be other suppliers of steerer tube dies. This one from "Park Tools" is unlikely to be cheap, but at least they're out there.
                      https://www.parktool.com/product/1-1-8-cutting-die-607?category=Frame%20%26%20Fork
                      It might even be worth seeing if a local bike shop has one you could borrow.
                      #546826
                      old mart
                        @oldmart
                        You might as well forget the threaded stem and just get a plain one with a clamp on top. You can get spacers to raise the handlebar clamp, if you do, then don't cut the fork tube to length first.
                        First, try googling "installing bicycle forks", there are many helpful answers.
                        Edited By old mart on 24/05/2021 14:47:00
                        #546836
                        Roderick Jenkins
                          @roderickjenkins93242
                          If it were me I would replace the headset as well (they don't need to be expensive). You will then have freedom to mix and match to suit your head tube diameter, head set and steerer tube.
                          Rod
                          #546839
                          Howard Lewis
                            @howardlewis46836
                            It used to be that all threads on cycles were 60 degree form and 26 tpi, but with the march of progress, and imported machines and parts that may longer be then case. So you might well be finding replacements that are metric in size and pitch.
                            You might find yourself making Imperial to metric adaptor collars!
                            #546840
                            Bo’sun
                              @bosun58570
                              The headset is going to have to change anyway, along with the stem, if Mike decides to go down the threadless steerer route. I would also suspect the choice of fork (depending on the quality required) to be somewhat limited, as many are now using tapered steerer tubes.
                              #546845
                              Robin Dufton
                                @robindufton85682
                                Posted by Bo'sun on 24/05/2021 15:35:48:
                                Many combos of modern parts aren't guaranteed to work on old Raleighs. I had a headache when trying to sort out a 70s bike and had to make a bush for BMX bars to fit. No stems would fit the fork so it had to be the Raleigh specific stem. Changing the forks would have meant making new bearing cups.
                                #546887
                                mike barrett
                                  @mikebarrett73459
                                  Thanks for all the helpful answers. I am/was trying to keep the bike standard but its begining to be a bit like Trigger's Broom … it would have been easier to buy a new bike but I do like repairing stuff!
                                  But.
                                  I can get a 1 1/8" 25 TPI die from one of the online suppliers in stock, buts it £45.
                                  I have managed to find a set of forks with a threaded steering tube (1 1/8" that seems to be the correct length.
                                  I am hopeful it will fit as the original forks were made by RST and seem to be standard set.
                                  Will know when the new forks arrive. if I need to lengthen the thread then I will buy the die.
                                  Regards Mike
                                  Edited By mike barrett on 24/05/2021 18:35:23
                                  #547027
                                    I share your pain, I have an early 90s MBK Triathlete IU'm trying to keep as original as possible, and the hardest thing to source was old style brake blocks to fit the Weinmann side-pull brakes!
                                    Is it a mountain bike or a road bike?
                                    Personally I wouldn't like to use a bike with a quill stem on anything more than pretty level ground.
                                    mike barrett
                                      @mikebarrett73459
                                      Posted by Neil Wyatt on 25/05/2021 12:53:13:
                                      Its a road bike so I am happy with the quill stem, I have never had any problems with it.
                                      Old bikes seem so difficult to maintain, there are no manuals and no standards for parts!
                                      I have had triumph classic cars for over 30 years (Herald, Vitesse, Dolly, Stag, GT6, TR6 and now have a 13/60 herald with EFI) and they are easy to run and maintain mainly because there is so much good information and data about the cars.
                                      cheers
                                      mike
                                      #547050
                                      Bo’sun
                                        @bosun58570
                                        Hi Mike,
                                        Unusual, a road bike with boingy forks. Surely that wold lift the front up a bit high for a road bike and change the head angle and steering geometry?
                                        It's not going to go down well with the hardened roadies out there.
                                        #547056
                                        Roderick Jenkins
                                          It used to be so simple, road bikes had 27" ( or 700C) tyres and mountain bikes had 26". Then hybrids came along with 700C tyres and may or may not have had suspension forks. Back in the day I remember that some pro teams tried suspension forks for the cobbles on Paris/Roubaix. I put my bike together from a cyclo cross frame with carbon forks and cantilever brakes. That was 12 years ago – nowadays you would call it a gravel bike. Definitions and styles constantly change, mostly to do with marketing. Mix and match any combination of bits and you will end up with something that a marketing focus group has already coined a name for.
                                          Modern life eh!
                                          Rod
                                          #547071
                                          Bo’sun
                                            @bosun58570
                                            Hi Rod, Gravel Bikes. Another fad maybe? or just road bike lovers not liking to admit that off-road biking isn't that bad after all.
                                            #547089
                                              Well you could also fit 650B rims to your gravel bike Rod so it can take some wider tyres or even slip a 26" MTB tyre on though 29ers seem to be the way to go on MTBs these days.
                                              Never had a problem with old style quill stems on my MTBs both solid fork and Rockshock equipped but then again did not have those big wide 750mm bars they ride now, think my Ritchey's were 500mm
                                              Anyone who likes their MTB racing should keep a look out on Redbull TV as they cover all the world cup rounds with both Short course XC on the Friday and Olympic XC on the Sunday. Replays of the first two round of this years worldcup available here and here
                                              And for a Small yearly Sub GCN is worth having as they do the full Cyclocross season in the winter and a lot of road stuff the rest of the year, just off to watch the Lotto Ladies tour now, ladies racing seems to be a lot more exciting than the mens as it is attack from the off not a Sunday club run to the last 20k as a lot of the mens stage races seem to be
                                              Edited By JasonB on 25/05/2021 18:56:50
                                              #547103
                                              Nimble
                                                @nimble
                                                Hi Mike,
                                                I also own a 13/60 Herald and would be interested in your EFI. any information you could give me would be of interest PM me if you wish.
                                                Nimble Neil.
                                                #547111
                                                mike barrett
                                                  @mikebarrett73459
                                                  Posted by Bo'sun on 25/05/2021 15:22:41:
                                                  Hi Mike,
                                                  I suppose its really called a hybrid not really a road bike or a mountain bike but perfect for the pot holed roads in Cambridge! Suspension forks and sprung seat pillar.
                                                  #547113
                                                  mike barrett
                                                    @mikebarrett73459
                                                    Posted by Nimble on 25/05/2021 21:57:21:
                                                    Hi Mike,
                                                    Nimble Neil.
                                                    Its got a rebuilt 1500 triumph engine, Newman cam, stage 2 head, Jenvey individual throttle bodies and wasted spark ignition.
                                                    All run by a upgraded Megasquirt MS2 controller. This means you can map the ignition and fueling based on input vacuum and throttle position. There is a high pressure fuel pump in the boot and pressure regulator on the fuel rail. It has broad band AFR sensor so can be run in closed loop to control the mixture. The Megasquirt software is excellent and allows you to tune and log data from the engine. It hasnt been on a rolling road but is still as fast as a 2L Vitesse but much more economical. Not cheap but a fun project that involves a lot of engineering, electronics and software.
                                                    The car also has an overdrive gearbox with close ratio GT6 ratios and a 3.89 diff. Its been around Scotland twice and down to Italy and up and down the alps!
                                                    PM if you more details.
                                                    regards
                                                    regards mike
                                                    #547283
                                                    Mark Rand
                                                      @markrand96270
                                                      What is all this B****cks? BIkes are brazed up from reynolds 531 tube, have 26tpi threads, have springs in the saddle for fragile sorts and the more modern ones have caliper brakes rather than the conventional rod brakes.
                                                      Bah! Humbug! I'm off to re-charge the carbide pot for the lights. cheeky
