Thread identification
Home Forums General Questions Thread identification
  • #27563
    david gregg 1
      @davidgregg1
      What is is this unusual thread
      david gregg 1
        @davidgregg1
        I have a Coventry die head and it is missing one of the machine screws which hold on the front cover plate ,the screw measures .172 o/d and is 40 tpi ,I have tried all the thread charts and cannot find what the thread is , was this a special thread used by the manufacturer.
        Hopefully somebody has come across the thread ,but I will probably end up having to make one
        #490195
        peak4
          @peak4
          From what I've read elsewhere, some of the threads used were specials.
          It was argued that it was so that you had to buy spares from the manufacturer.
          It seems to fall in between two model engineering 40tpi threads, so if you have Herbert chasers for one or the other, you could probably use the head itself to make them.
          There's a table HERE
          Bill
          #490197
          bernard towers
            @bernardtowers37738
            Yes it is a special but they are available from the firm that now owns them (the name escapes me at the moment) it is a company that makes thread rolling heads. From memory the are about a fiver each!. I am surprised that you have only one missing most of the ones I’ve seen only ever have two screws left in them!
            #490198
            bernard towers
              @bernardtowers37738
              Try wiseman threading tools
              #490305
              Howard Lewis
                @howardlewis46836
                Very slightly rounded, 11/64" is 0.1719" and is listed in Zeus Charts as 0.1719.
                No 40 tpi ME threads are listed as 11/64
                None of the figures quoted match BA or BSP.
                So it may well be a "Special" 11/64 x 40 tpi., exclusive to the Coventry Die Head
                What is the thread form? 55 degrees is Whit, which is what I would feel inclined to expect, but if it is a special it could be different.
                #490662
                martin haysom
                  @martinhaysom48469
                  nothing in my caxton engineering workshop data [1947] but if its helps all mention of 40 tpi is in relation to whitworth thread form
