Posted by Bo'sun on 23/12/2020 14:31:11:
According to the chart. 0.2, 0.3, 0.4, 0.5, 0.75, 1.0, 1,25, 2.0, 2,5 & 3.0mm pitches are possible (depending on the relevant TDI number/numbers) with the 30T gear, unless I'm reading it wrong. Sorry, but I can't post a pic of the chart.
That is true but it is a case of marketing trumping engineering.
For a 3mm pitch leadscrew, assuming the necessary leadscrew gears are present, the following can be cut with no indicator at all:
0.2, 0.25, 0.3, 0.5, 0.6, 0.75, 1, 1.5, 2, 3.
The thread dial indicator is required only for 0.4, 1.25 and 2.5.
Any pitch that is a factor of the leadscrew pitch does not need an indicator.
As Thor says, the addition of a 28t gear (and dial) is the best 'bang for your buck' in adding missing pitches. Potentially, you could cut it on a blank sized for 30t then you do not need to adjust the meshing centre distance when changing gears. Alternatively, recut both gears on a 29t-size blank.
Edited By DC31k on 23/12/2020 14:45:07
Edited By DC31k on 23/12/2020 14:49:47
