This weeks mystery Object / Tool ??
Home Forums General Questions This weeks mystery Object / Tool ??
  • #338694
    Martin King 2
      @martinking2
      This came in the week inside a crate of tools.
      Several people have said mousetrap but I feel they are having a laugh!
      The small piece inside is well made and fits its recess quite precisely, nicely made and put together.
      Any guesses anyone?
      Cheers, Martin
      #25783
      Martin King 2
        @martinking2
        #338698
        Andrew Tinsley
          @andrewtinsley63637
          Fruit press?
          Andrew.
          #338700
            My guess is you press something quite gently in it. Probably soft and a bit sticky – hence the string to lift the block and the lose bit to stop things sticking in the bottom?
            N.
            #338701
            Gordon W
              @gordonw
              A joke mousetrap. Having spent all morning in the loft trying to shift the little ******s I may be biased.
              #338702
              Clive Hartland
                @clivehartland94829
                It is a 'Mole Trap'.
                #338704
                peak4
                  @peak4
                  Posted by Clive Hartland on 28/01/2018 15:33:29:
                  Here You Go, or mice maybe, just lacking the trigger mechanism; note the little notch on the paddle shaped bit.
                  Bill
                  Edited By peak4 on 28/01/2018 15:43:33
                  #338706
                  Martin King 2
                    @martinking2
                    Amazing! Just tried it out and it works perfectly, very sensitive indeed. Many thanks for the info.
                    The trigger bar is the small piece of wood that fits neatly on the end notch and into the side of the large block, very light retention, just a tiny light touch on the internal paddle and off it goes.
                    Martin
                    #338729
                      How heavy is the block?
                      I can't imagine it's very lethal?
                      #338745
                      Russell Eberhardt
                        @russelleberhardt48058
                        Posted by Neil Wyatt on 28/01/2018 18:15:01:
                        Probably just holds the mouse in place and it dies of fright crying
                        Russell
                        #338765
                        Martyn Duncumb
                          @martynduncumb88863
                          I would tend towards the mousetrap theory. There is a very similar contraption in the museum in Framingham Castle that is described as a mouse trap.
                          Martyn
                          #338771
                          norman royds 2
                            @normanroyds2
                            well they look very dog friendly trouble it wont fit under the cupboard norm
