THE NUMBER 9 !
THE NUMBER 9 !
Home Forums Clocks and Scientific Instruments THE NUMBER 9 !
Viewing 25 posts - 1 through 25 (of 28 total)
  • #559647
    noel shelley
      @noelshelley55608
      Edited By noel shelley on 24/08/2021 13:20:34
      noel shelley
        @noelshelley55608
        #559651
          Brilliant star
          Nigel Graham 2
            @nigelgraham2
            Hee-hee! I like it!
            I'm baffled by the 5 o'clock one though.
            How does the square-root of 9! = 6 as I read it; or come to that the square-root of 8! = 5?
            Nor does it work by the factorial of the square-root of nine.
            #559669
            duncan webster 1
              @duncanwebster1
              (sqrt(9))! – 9/9
              3! – 1
              3*2*1 – 1 =5
              Does Bodmas cover factorials?
              Edited By duncan webster on 24/08/2021 15:14:08
              #559670
              Ramon Wilson
                @ramonwilson3
                Ah! you'd need a calclator to turn that into real timelaugh
                Nice one Noel
                Tug
                #559671
                Nicholas Farr
                  @nicholasfarr14254
                  Hi Noel, very good, however I've not had course to come across the type of equations for 5, 7 or 9, the 7 one taken the longest time for me to figure out on one of my fraction capable calculators.
                  Regards Nick.
                  #559672
                    If you got 601.3952191045344 for 5O'Clock, join my club.
                    Also, am I right in saying that the digits of the hours expressed in seconds always add up to 9?
                    e.g.:
                    1AM = 3600s so 3+6+0+0 = 9
                    4AM = 14400 so 1+4+4+0+0 = 9
                    9AM = 32400s so 3+2+4+0+0 = 9
                    11AM = 39600s so 3+9+6+0+0 = 18 & 1+8 = 9
                    Bound to be useful for something. Is there a prize?
                    sad
                    Journeyman
                      @journeyman
                      I agree, the 5 is a bit iffy, needs brackets as per Duncan's explanation. If you fancy the real thing for your workshop wall available at a nearby South American rain-forest for about 15quid.
                      Nigel Bennett
                        @nigelbennett69913
                        I'm sure there must be a much simpler expression for the 9 o'clock position, but I can't imagine what…
                        #559688
                        Ady1
                          @ady1
                          cool!
                          Engineers or mathematicians xmas pressie sorted too
                          #559696
                            Posted by Journeyman on 24/08/2021 15:52:00:
                            I suppose it’s fair … given that the ‘bang’ is outside the sqrt sign
                            duncan webster 1
                              @duncanwebster1
                              pressed the wrong button
                              Edited By duncan webster on 24/08/2021 19:51:55
                              #559706
                              Brian G
                                @briang
                                Posted by SillyOldDuffer on 24/08/2021 15:40:42:
                                e.g.:
                                sad
                                Probably been won almost as soon as we started using base 10 with arabic/indian numerals Dave, as the sum of the digits of any multiple of 9 is always a multiple of 9, and 3600 = 400 x 9.
                                I just checked and the same thing seems to work in other bases such as Hex, so that the digits of multiples of F add up to multiples of F. I'm beginning to understand why I was put in the applied maths stream at school as this sort of thing just confuses me.
                                Brian G
                                Edited By Brian G on 24/08/2021 20:37:57
                                #559710
                                pgk pgk
                                  @pgkpgk17461
                                  Trachtenberg speed system multiplying by 9
                                  Which looks clumsy in the example until the rules are second nature but the whole system was apparently able to teach kids to calculate a 15 digit number x a 15 digit number in under a minute?
                                  Link
                                  https://en.wikipedia.org/wiki/Trachtenberg_system#Multiplying_by_9
                                  pgk
                                  #559715
                                  Nicholas Farr
                                    @nicholasfarr14254
                                    Posted by Michael Gilligan on 24/08/2021 19:47:10:
                                    Hi, this is how I did it on my calculator.
                                    This is the only way I could get it on my calculator with any brackets, any other combination of brackets gave a wrong answer or a system error.
                                    Regards Nick.
                                    Edited By Nicholas Farr on 24/08/2021 21:37:38
                                    #559717
                                    Nigel Graham 2
                                      @nigelgraham2
                                      Thank you Duncan.
                                      I'm glad I was not the only one who'd not spotted the invisible brackets that make it work.
                                      I've never seen a clock like that previously.
                                      Anti-clockwise clocks yes.
                                      A clock with its otherwise plain dial given coloured segments to show pub opening times, yes.
                                      A clock with fancy single-digit sums though…. No. I like it!
                                      Edited By Nigel Graham 2 on 24/08/2021 21:55:11
                                      #559721
                                      noel shelley
                                        @noelshelley55608
                                        Gentlemen I'm glad it has generated some thought and comment, BUT I can claim no credit for it ! It was sent to me by an old school friend who paid less attention in maths than me, he also sent the WHAT IS IT I posted some weeks ago. I felt it was worth sharing. Ah well, Time Flies. Noel.
                                        #559727
                                        duncan webster 1
                                          @duncanwebster1
                                          The 7 would be better as 9 – sqrt(9) + 9^0, which would be 9 – 3 + 1 = 7
                                          The symbol for 0.99999……… in my young date was a dot above the 9, not a line
                                          Anyone know where I can get one, apart from Journeyman's South American Rainforest, which I must admit I didn't get
                                          #559728
                                          Grindstone Cowboy
                                            @grindstonecowboy
                                            Duncan – it's also a big river. I'm assuming we aren't allowed to mention the actual website?
                                            Rob
                                            #559729
                                            Anonymous
                                              Posted by duncan webster on 24/08/2021 23:45:05:
                                              But unfortunately introduces the numeral " 0 " ….
                                              #559731
                                              pgk pgk
                                                @pgkpgk17461
                                                The search phrase "Math Clock buy uk" throws up multiple retailers and many more variations.
                                                pgk
                                                #559734
                                                  Posted by Peter Greene on 25/08/2021 01:50:58:
                                                  … which sometimes goes by the alias (9-9)
                                                  not done it yet
                                                    @notdoneityet
                                                    Posted by Nigel Bennett on 24/08/2021 17:08:10:
                                                    Yep, I thought that, too. After all it is about the number 9. KISS principle and all that.
                                                    Now set about the minute hand?!
                                                    Duncan, Ama-zing or -zon.
                                                    #559748
                                                    Journeyman
                                                      @journeyman
                                                      Of course if you have an aversion to 9's and prefer computers over maths there is always this version:
                                                      Available from the same source along with a few other strange ones. Digital binary is quite good!
