Ok. If you can’t beat ‘em join ‘em. I apologise in advance that this post has nothing to do with model engineering!
Firstly Michael G I would happily carry out the analysis you suggest but fear I will not live long enough to publish the results.
If I may drift back to the original post I drive a 2018 Kia Sportage which has not one but two visual indications of the current speed limit, one is derived I understand from the GPS/SatNav and is displayed on the touch screen, the second is read from the road signs by one of five cameras on my vehicle (not including my dash cam) and displayed in the instrument cluster. It has many other safety(?) aids and so far, in nearly 5k miles they have behaved faultlessly.
Of course I have the ability to switch all these aids off, including the speedometer, if I so choose. It’s called a brain and it is very easy to slip into ignore mode! I am not alone in this. Tootling down the motorway at a steady 80 I am usually overtaken by a string of vehicles, mostly of Germanic origin, desperately trying to catch the white van at the head of the procession. They clearly have the ability to engage ignore mode as well.
Now back to advances in engineering which I think if my memory is correct was briefly mentioned on page two or three of this thread.
You may guess from my stage name that I am of a certain age! I can remember when most make and model of cars had round headlights, probably Lucas, with replaceable filament bulbs, unless you had gone upmarket and fitted sealed beams. Break a headlight and the local scrappy would be able to offer a range of replacements and providing it was the right diameter it would probably fit. It probably cost little more than the price of a gallon of four star (4s 6d plus 1d for a shot of Redex I recall).
Fast forward to the present day. Many cars now have what the industry call “signature headlights”. You know the type, sculpted to blend in with the flowing lines of the bodywork and with LED displays (the signature) which are usually unique to a make, sometimes unique to a model and even unique to a trim level within a model range. Scrappy’s no longer exist but try getting the specific replacement signature headlamp from your local vehicle dismantler. No chance. You have no choice but to go to a main dealer. Most modern headlights slot into a fixing on the body and are secured by a single screw, presumably engineered to make fitting swift and easy on the production line.
It only takes a minor front end shunt to break the fixing on one of these lights which are of course sealed units. Forget the cost of the cracked grill or rippled bumper the cost of the headlight alone will I am sure far exceed the combined personal and compulsory excess on your insurance. Do you drive a car with a signature headlight? Any idea how much a replacement costs? Go on check I dare you and report back here.
I’ll start the ball rolling. A headlamp for a Range Rover Velar will set you back a little over £2000! That is for one not a pair!!
As for advances in engineering the same vehicle has, like many cars, a puddle light in the door mirror. The Velar doesn’t just illuminate the puddle it throws a silhouette of the vehicle onto the puddle as well. Sorry but shadow art on a car is taking engineering too far!
This discussion would be so much better in a pub but it’s not my round and I’m off to the workshop. Drive safely.
