Over the years, I have tried them all, even the real crappy carbon ones from a well known supplier who can supply almost any size to the model engineer, All I can say is you can soften them down a bit and use them to make other things out of. Almost all the taps in their full and relatively expensive kits cut oversize and the dies, undersize.
I have recently spent over a grand on tap & die sets, getting ready for my final fling, my other Presto tap & die carbon sets have lasted me nearly 30 years, they just don’t make them like they used to, but they are now getting rather dull and beyond resharpening. I doubt if my new ones will have to last that long.
I now only use two places for my threading equipment, the first is Arc Euro, their HSS serial metric tap sets are fantastic value for the quality you get. The other is the Tap & Die company.
Their HQS ones look expensive, but in the long run, or if you buy in bulk, they will far outlast anything else for the price, especially if cutting a lot of stainless steel. They cut stainless as well as a normal tap will go through brass.
If I am doing a large production job, I buy the taps and dies in bulk, and they come out at around £2 to £3 each. I hardly ever break a tap or die, that is because I always use a very good quality high pressure lubricating oil, and at the first sound of a squeak during cutting, it is got rid of.
I suppose it all depends on how much threading you do.
If you only do the odd one now and again, then treat yourself to some HSS ones, but if like me, where I could be doing hundreds a day, then the quality jobbies are the way to go.
