Hi, and thank you, to the two Michaels above …
@ Michael W … yes, you are totally correct in what you say … I have to stress that there is a difference between commissioned instruments, where the luthier is building to the player's exact specs, and what I would call "retail high end " instruments, wherein somebody like the admirable Trevor Moyle (who runs TAMCO) takes it upon himself to commission an instrument from a top flight luthier with the objective of selling it on to a customer down the line. That is where my Claxton guitar sits …I bought it retail, already built…If I had commissioned it ab initio I would have incorporated all the specs which I am about to implement as a retro-fit..
Custom luthiers are indeed able to offer clients features which facilitate playing the instrument standing up.
First and foremost would be the so-called "Manzer wedge" which entails the body of the guitar being built with the bass side being around 1/2"( or more or less) thinner than the treble side. This doesn't sound like much, but it actually makes for a huge difference in playability, especially when standing.
The other innovative feature which many luthiers are offering is the soundboard bevel, originally the brainchild of the amazing Canadian luthier Grit Laskin, wherein the soundboard /side junction on the lower bout of the guitar, instead of being a 90 degree angle as in most guitars, has a 45 degree bevel between the top and the side, making for a much more comfortable contact between the right hand arm and the guitar.
These features however will only ever be available on custom built instruments, which mine is not..
@Michael G …hi Michael … I will look forward to hearing about your reservations about the Z bar , all opinions gratefully received and welcomed.
I think I see where you are coming from with the end cap thing …you may be thinking …remove the endcap, do your stuff …if it all goes pear shaped then glue the endcao back on and nobody is any the wiser. And yes, the end cap is in fact ebony, glued on to the heel.
Thing is, I think it will actually look a whole lot neater to have a polished ebony end cap with a polished brass insert, than to have a mahogany triangle with a brass insert, which will inevitably end up looking like a job awaiting completion.
