So….getting colder outside – time to start the triple!
Crankshaft in the kit has the 6x counter weights cast, everything else has to be made from stock. I wanted to get some comments before starting the job…
The crankshaft and journals are made from 3/8" dia mild steel according to the drawing. I have some 1144 material but it is slightly undersize by about 3 thou and so i am wondering if i should use this or get some silver steel/drill rod which will be precision ground? My concern is that if it is undersize, it won't be a great fit in the bearings which will be reamed (once made) to 3/8". Thoughts?
Whats the best way to set the 3x sets of webs at 120deg from each other for drilling and pinning?
Any tips on registering the counterweights against the crank webs to keep them straight and located properly? Or would you advice throwing them away and machining brand new webs with counterweights from 1.75" stock (i have 1144 in stock)
