I previously raised the problem on this thread of the backgears of my big-bore Myford Super 7 Plus that didn’t line up. David Clark put me in touch with Derek ‘DAG’ Brown who used to demonstrate for Myford. He in turn put me in touch with Darren Boden, the ex-Myford fitter. Both were most helpful and this was the outcome for the benefit of other big-bore users who might have the same problem.
My lathe was made in 2001 and was one of the very first big bore machines. It would have been made with a 67 tooth bull wheel. Around 2006, Myford changed over to a more useful 60 tooth bullwheel but with non-standard DP. My lathe, which was kept by Myford as a demonstration machine, must have been retro-fitted as it has a 60 tooth wheel. Darren explained that some time after this changeover, it was noticed that the backgears sometimes did not line up and fouled the crescent-shaped backgear key, as in my case. A special longer eccentric was made to solve this problem, stamped with a ‘C’ for Connoisseur. This modification had not been applied to my lathe. Darren was sure that such eccentrics would be amongst the spares stock acquired by RDG. I tried them but they did not respond, so I solved the problem myself.
It wasn’t necessary to make a new eccentric but it did mean removing the headstock spindle to gain access. I added a 0.100” thick bronze spacer on the right of the backgear cluster to move it to the left the required amount. On the left hand end, I discarded the circlip holding on the cluster and replaced it by a bronze washer held on by a screw tapped into the end of the eccentric spindle. The washer is stepped to give just the right amount of side play in the gears. I took a guess at the sizes needed and made both parts on the lathe before stripping out the headstock spindle. All is now sorted.
Andrew M
