One of these will do it but the cost 😭
Mogens Kilde described a wire straightener in MEW 271-272 that could be adapted to do the same thing if you don't mind making one .
I wonder how you would go running the tube through a block of wood say 2 or 3 inches long with the appropriate hole drilled through it then feed the tube through the hole and clamp the end of the tube in a vise and drag the block along the tube – might need a bit of soap for lube , never tried it – just a thought !
Edited By XD 351 on 10/12/2018 03:59:28
