Stopping milling chips going everyehere
Home Forums General Questions Stopping milling chips going everyehere
  • This topic has 40 replies, 23 voices, and was last updated 7 May 2025 at 11:35 by Howard Lewis.
Viewing 16 posts - 26 through 41 (of 41 total)
  • #794355
      Anyone tried blowing chips, which is common on Machine Centres?  The job and cutter are cooled by aimed blasts of gas that also directs the swarf into a collection area.
      The blast is often compressed air, usually supplemented with an aerosol cutting fluid, but because air is an Oxidiser, liquid Nitrogen is also widely used – it’s very cold and mostly unreactive.   Argon when Nitrogen is unsuitable, but it’s pricey.  When swarf is produced by the ton, it pays to keep it clean – avoid mixing metals and contaminating coolants.  Blowing is cleaner than other methods.
      The “collection area” can also be elaborate.   At least one Machine Centre includes a conveyor belt, needed because the machine produce 1500kg of swarf per shift.  Another loads swarf into cartridges – no mess.
      Obviously over the top at home, but manually blowing chips with compressed air might be an alternative to a vacuum.  Needs care: professional blower systems are fully enclosed, making it unlikely the operator will be injured by an accidentally misdirected faceful of hot swarf!
      And should out of control swarf be a problem in a home workshop?  Pushed hard with carbide, my 1.5kW-ish lathe and mill are both powerful enough to spray chunky red-hot steel granules.   Metal comes off quickly and finish is excellent.   BUT, because the granules are hot enough to burn skin, fly up to a couple of metres, and might start a fire, I don’t cut that hard.  Instead, I back off enough to produce ribbons of swarf that stay on the machine.  When the heap gets too big, I stop and clear it manually.   I’m not in a tearing hurry, and am mindful that my hobby machines aren’t designed to remove metal at high speed.
      Dave S
        @daves59043
        I’m still finding Swarf from this op miles from the machine:
        https://youtube.com/shorts/kbY15HNpIQg?feature=shared
        Its not even small swarf:
        https://youtube.com/shorts/722Ub2RuWxc?feature=shared
        On my big mill I just try and stand out of the way and then clear up later.
        Im building an enclosure around the CNC, as the swarf it generates seems to be more needle like.
        SWMBO is tolerant, but there are limits…
        Dave Halford
          @davehalford22513
          Some retired mills seen on Ebay have an acrylic shield with doors on the table. Some model makers use a ‘cut about’ 4 pint milk carton, scoop shaped to catch swarf, somewhat small for your needs.
          #794371
            Dave I use air on the CNC not really for cooling but to just keep the area around the cutter clear of swarf. I only use a low pressure and not too large a flow rate otherwise it will just increase the problem of spreading the chips downwind.
            IPA is the one to add to the air if you want cooling with the bonus it does not leave you with a pile of wet soggy chips which nobody wants.
            #794378
            duncan webster 1
              @duncanwebster1
              Inhaling IPA won’t do you any good, and spraying an aerosol sounds like a good way of getting it airborne
              #794386
                The likes of Datron have extractors on he enclosures so not really a problem particularly as the MQL systems use such a small amount it would not even go above accepted levels, you are looking at a few mls per hour. The liquid is feed into the air supply not sprayed from a can.
                My own MQL which I use with a neat fully synthetic cutting fluid delivers about 10 to 30mls per hour and I generally use it on the lowest rate.
                #794427
                samuel heywood
                  @samuelheywood23031
                  Maybe i’m running too slow, but i don’t find my milling chips travelling too far.
                  I do have issue with drilling on the mill, at least with (mild/ish) steel, this gets chucked everywhere, there’s probably some still under the fridge as i write this~ being as i use it in the kitchen!!
                  Drilling on the lathe is SO much nicer.
                  #794497
                  Hollowpoint
                    @hollowpoint
                    I like This guys approach. I’m sure something similar could be made for a bigger mill, perhaps using perspex.
                    #794499
                      That is similar to how the trough on my CNC works. It will catch 99.9% of the chips from a standard cutter and a fair bit from the face mills provided the work is not too far up from the table. Though with 96 similar cuts to this one I did need to scoop out the shavings with a dustpan after every couple of cuts.
                      #794500
                        #794529
                          “Man Glitter” … Love that description !
                          Very neat fence though.
                          Vic
                            @vic
                            I did try fitting some clear plastic screens to contain the chips but I gave up with that idea as they got in the way. I now accept the problem and hoover up afterwards. I do though wear a face shield that I bought for wood turning sometimes if hot chips are headed my way. I always wear eye protection anyway but hot chips on the face can be very unpleasant.
                            #794570
                            Andrew Crow
                              @andrewcrow91475
                              Even worse when drop down the neck of your shirt 😅
                              #796718
                              petro1head
                                @petro1head
                                So far20250423_114015
                                #796731
                                  I took these yesterday after nearly 2hrs of cutting a bit of cast iron, though only about 40mins was adaptive cuts which tend to produce the most swarf. As you can see the trough I have mentioned catches almost all of it. Adaptive was with a 6mm 3-flute at 5000rpm, a faster spindle speed may throw it a bit further. Also had the air on the whole time.
                                  20250506_10391720250506_10393020250506_103924
                                  #796781
                                  Howard Lewis
                                    @howardlewis46836
                                    For ferrous material, siting a strong magnet under some newspaper will catch a lot of chips.
                                    I always do this when machining cast iron. Once the job is done, removing the magnet allows the newspaper to be used to carry the swarf to a disposal point.
                                    If there is a lot of swarf, a “stick” magnet, in a copper or aluminium tube can be used to carry it away, a little at a time. Withdrawing the magnet allows the swarf to fall away into whatever receptacle is used for swarf disposal.
                                    It might be worth having a rubber O ring around the outside of the tube, to prevent the swarf trying to follow the magnet up the tube as it is withdrawn.
