If you can't get the glass tube, its still possible to do the build by using stainless steel, you can make the cup shape by welding an end on a bit of tube, job for a TIG welder, or you can carve it out of solid bar, takes time, but well worth it. Both the hot cap and the displacer can be made the same way.
One of my motors, built from junk found in the workshop. Power cylinder 3/8" bore x 12" stroke. The hot cap is made from the steel case from a dead AA size Nicad battery.
Ian S C
