Hi Norm,
To clarify, the design basis for the safety valve vent-cap orifice cross-sectional area should actually assume critical flow through the orifices. In other words, if the valve design is correct then the critical flow-rate through the vent-cap orifices must exceed the steam-generating capacity of the boiler.
That's the reason that I feel confident that you'll be fine with your modifications provided that the original valve design was sound – you have a greater total vent-cap orifice cross-sectional area now than had the original design.
If you want to It's pretty straightforward to calculate the critical flow-rate for your orifices and it looks like you've already figured that out. You don't need to worry about velocity, and Gareth has provided the pressure-drop ratios in his Email above. As Gareth mentions, make sure you're using absolute pressure and not gauge pressure.
Taking things further, the trick is to work backwards. You know the steam leaves the vent cap at atmospheric pressure – that's your starting point. Hence you know the pressure on the other side of the vent cap when the valve is maxed out is the critical pressure. Hence you know that the limiting pressure drop across your valve seat will be the difference between maximum boiler pressure and that critical pressure. Hence you can calculate the valve's Cv (which is a measure of the valve's flow capacity) and hence come up with an appropriately-sized plug and seat arrangement to achieve the needed flowrate given your calculated across-the-seat pressure drop.
You do raise another question which is reasonable but which would be much more difficult to answer without a doctorate in computational fluid dynamics and/or extensive lab testing. To paraphrase your question, "how small a hole is too small and how long a hole is too long"? I for one don't know an easy way to answer that when working at the micro-extreme. I imagine that the orifice shape, length, interior surface roughness, and steam viscosity play a part however.
Best regards
Steve
Edited By stephen goodbody on 09/09/2020 20:20:10
Edited By stephen goodbody on 09/09/2020 20:32:00
