I had turned the bar to 1/2" so don't believe that was an issue, and the die holder seems OK with the 3/8" BSW die, I will double check the screw points and holder to make sure that they are all OK, I had made sure they were clean, so no swarf trapped, also I suspect it is the correct holder as the die went in easily, I did not have to push or compress it.
While it could easily be operator error I have used a dies to thread many parts before, adjusting to get a good fit, hence the question. Would a blunt die dig-in and cut under-size?
Seems the bathroom extractor has packed up so bang goes my time in the workshop this tomorrow
I will update on my findings when I have any.
Baldric.
